Hello Guest it is October 15, 2026, 08:02:09 AM
Author Topic: Lathe homing in the wrong direction  (Read 22306 times)
« on: October 24, 2023, 10:46:58 AM »
When I press Reference All Axes, the Z axis on my lathe homes in the positive direction.  I need it to home in the negative direction.
I changed the direction in Control, but regardless of what direction I choose, the Z axis homes in the + direction.  I have restarted Mach4, restarted the PC, changed direction to + and - but no matter what I do, the lathe homes in the wrong direction.  Jogging works in the correct direction, BTW.
See attached document for screenshots of the configuration.
Re: Lathe homing in the wrong direction
« Reply #1 on: October 24, 2023, 01:49:20 PM »
Configure > Control > Homing > Here you select the direction.
If that's not fixing it, something's broken send an email to support.
« Reply #2 on: October 28, 2023, 03:31:28 PM »
Not sure your entire system setup.  However I have had this issue in the past.  It happened when one of the wires for the directional input to the stepper driver broke.  If that happens no matter what you do your motion will only be in 1 direction.
