Hello Guest it is November 08, 2026, 02:39:58 AM
Author Topic: mach3 motor not moving  (Read 9484 times)
« on: October 21, 2023, 03:36:17 PM »
maching was put
machine was put down working for 3 months   start up this morning  everything works except motors
check configuration every thing correct  when i power up i dont get  that thump sound when the power is applied
to motors.  Mach 3  dro moves       seem like no power is getting to motors
pmdx-122 directional board   Geckodrive 6203v   estop disconnect  wood router
does anyone have any ideas   thanks Paul
Re: mach3 motor not moving
« Reply #1 on: October 21, 2023, 04:39:38 PM »
The "thump" is normally expected when the DC power is applied to a G203V driver and associated motor.
Try turning the motor without power turned on and also after power turned on.
If they feel the same, it is likely that DC power is not getting to the G203V.
If the motor becomes much more difficult to turn by hand after power is turned on, then the driver is likely OK and your Step and Direction signals are not getting to the driver.
Steve Stallings
www.PMDX.com
« Reply #2 on: October 28, 2023, 03:37:16 PM »
I have had this issue in the past, but probably not the same root cause.  I have found that after time either the controller board gets scrambled, the driver, or the software.  A full hard shutdown of the controller, computer (software), power, etc.  Cleared it up.  Also maybe a directional signal broken wire?  You were running ok, shut down, then after startup nothing moves?
