Hello Guest it is October 15, 2026, 04:54:11 AM
Author Topic: DRO not showing a straight line  (Read 14920 times)
« on: October 18, 2023, 08:04:51 PM »
Hello, was wondering if anybody has had the same issue and what might be wrong, or something I could change to fix this issue.
I'm using
Win10
CNC4 newbie
TB 6600 Drivers
Nema Stepper 23 Motors
ESS MB3 BOB
Mach4 4809
ESS 283
Machine was returning to Z0 and I noticed a triangle in the return path.
See attached files.
Also included gcode file i used, changed to txt. you will need to change back to .gcode
Offline Bill_O
  •  615 615
Re: DRO not showing a straight line
« Reply #1 on: October 20, 2023, 11:05:00 AM »
the path is showing all the moves after the cut it finished cutting
you started at 0,0 and when it finished you went back to 0,0
« Reply #2 on: October 20, 2023, 04:51:25 PM »
I'm very sorry for the subject saying DRO. I apologize for that. It should say Tool Path Window.
Re: Tool Path not showing a straight line
« Reply #3 on: October 20, 2023, 04:52:35 PM »
I'm using
Win10
CNC4 newbie
TB 6600 Drivers
ESS MB3 BOB
Mach4 4809
ESS 283
See attached files.
Offline Bill_O
  •  615 615
« Reply #4 on: October 23, 2023, 08:00:45 AM »
I understood what you were talking about.
See my previous reply.
« Reply #5 on: October 28, 2023, 09:06:26 PM »
Have another screen capture of this issue.
  •  9,374 9,374
« Reply #6 on: October 29, 2023, 05:06:58 AM »
Its probably just a glitch in the tool path display - if it does not affect the work then just ignore it.
« Reply #7 on: October 29, 2023, 05:41:34 PM »
Thank You Tweakie, I kind of suspected that might be the issue. Ty for the help.
