Hello Guest it is October 11, 2026, 09:47:00 PM
Author Topic: Option stop led  (Read 13531 times)
Option stop led
« on: October 13, 2023, 08:06:37 AM »
When using option stop, the led blinks. But while the G-code is running the led goes out until the M01 is read at which time the led starts blinking again. My issue is sometimes I want to turn on the option stop on when the G-code is running so the machine will stop at the next M01 ( to check part dimensions) but the led doesn’t start blinking until the M01 is read so it’s hard to tell if you actually turned the option stop on. Maybe if while the option stop button has been pressed it could change color it indicate it’s on might help.  I’m pretty sure this is possible. Can someone point me in the right direction on how to accomplish this?
Art
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: Option stop led
« Reply #1 on: November 09, 2023, 12:42:32 PM »
Why not change the button to a toggle button and set the button down to blinking, works well in my screen.
DazTheGas
Re: Option stop led
« Reply #2 on: January 18, 2024, 07:44:07 AM »
Thanks DazTheGas. I have one question. On the original button under enabled states there is a lot of states there. Do I need all those? And is there an easy way to copy and paste that?
Art
