Hello Guest it is November 26, 2026, 09:55:01 AM
Author Topic: change virtual keyboard  (Read 17832 times)
« on: October 12, 2023, 02:54:41 AM »
Good morning
I use this macro to insert values into the dro
I have a problem, if I enter the value and press "OK" it's fine, if I press "CANCEL" it comes out and resets the dro, is it possible to modify it?
in the sense that by pressing "CANCEL" it comes out but DOES NOT change the value in the database. Since it is not within my capabilities/expertise, is there anyone who can help me?
Greetings
' TAST ASSE X
Global value As String
Sub Main
   'declare variables
   Dim Pos As Double
   Dim OldDroValue As Double
   Dim MinPos As Double
   Dim MaxPos As Double
   Dim DroNum  As Integer
   'preset the variables
   MinPos = -1000.0
   MaxPos = 1000.0
   DroNum  = 800
   'get the actual DRO value
   OldDroValue = GetOemDro(DroNum)
   'show the virtual keyboard
   Call NumericKeyboard(DroNum,MinPos,MaxPos)
   'get the new DRO value
   Pos = GetOEMDro(DroNum)
End Sub
'TPS 01.12.2017
'numerische Eingabe
Function NumericKeyboard(ByVal DRONum As Integer , ByVal Min As Double , ByVal Max As Double) As Double
   Dim title As String
   value = "" 'GetOemDRO(DRONum)
   title = Header
   Speak ("  ASSE x") 'Avviso Vocale
   Begin Dialog UserDialog1 410,10, 125, 240, "INSERIMENTO VALORI:"  , .Enable
   Picture 0, 0, 125, 210, "c:\mach3\bitmaps\Ita_Screenset\TASTIERA.bmp"
      PushButton 20, 10, 25, 25, "7", .but7
      PushButton 50, 10, 25, 25, "8", .but8
      PushButton 80, 10, 25, 25, "9", .but9
      PushButton 20, 40, 25, 25, "4", .but4
      PushButton 50, 40, 25, 25, "5", .but5
      PushButton 80, 40, 25, 25, "6", .but6
      PushButton 20, 70, 25, 25, "1", .but1
      PushButton 50, 70, 25, 25, "2", .but2
      PushButton 80, 70, 25, 25, "3", .but3
      PushButton 20, 100, 25, 25, ".", .butD
      PushButton 50, 100, 25, 25, "0", .but0
      PushButton 80, 100, 25, 25, "<-", .butB
      PushButton 20, 130, 25, 25, "+/-", .butN
      PushButton 50, 130, 25, 25, "00", .butA
      PushButton 80, 130, 25, 25, "Del", .butDel
      TextBox 20, 160, 85, 18, .FText
      PushButton 20, 185, 40, 18,"OK", .OK
      CancelButton 65, 185, 40, 18
      Text 50, 215, 100, 18," ASSE X"
   End Dialog
   Dim Dlg1 As UserDialog1
   Dlg1.FText = CStr(value)
   x = Dialog( Dlg1 )
   NumericKeyboard = CDbl(Dlg1.FText)
   If CDbl(Dlg1.FText) < Min Then NumericKeyboard = Min
   If CDbl(Dlg1.FText) > Max Then NumericKeyboard = Max
   SetOEMDro(DRONum,NumericKeyboard)
End Function
Function Enable( ControlID$, Action%, SuppValue%)
   Select Case Action%
      Case 1
      Case 2 'Button wurde gerückt
         If ControlID$ = "but0" Then
            value = CStr(value) + "0"
            DlgText "FText", CStr(value)
            Enable =1
            Speak ("0") 'Avviso Vocale
         End If
         If ControlID$ = "but1" Then
            value = CStr(value) + "1"
            Enable =1
            Speak ("1") 'Avviso Vocale
         End If
         If ControlID$ = "but2" Then
            value = CStr(value) + "2"
            Enable =1
            Speak ("2") 'Avviso Vocale
         End If
         If ControlID$ = "but3" Then
            value = CStr(value) + "3"
            Enable =1
            Speak ("3") 'Avviso Vocale
         End If
         If ControlID$ = "but4" Then
            value = CStr(value) + "4"
            Enable =1
            Speak ("4") 'Avviso Vocale
         End If
         If ControlID$ = "but5" Then
            value = CStr(value) + "5"
            Enable =1
            Speak ("5") 'Avviso Vocale
         End If
         If ControlID$ = "but6" Then
            value = CStr(value) + "6"
            Enable =1
            Speak ("6") 'Avviso Vocale
         End If
         If ControlID$ = "but7" Then
            value = CStr(value) + "7"
            Enable =1
            Speak ("7") 'Avviso Vocale
         End If
         If ControlID$ = "but8" Then
            value = CStr(value) + "8"
            Enable =1
            Speak ("8") 'Avviso Vocale
         End If
         If ControlID$ = "but9" Then
            value = CStr(value) + "9"
            Enable =1
            Speak ("9") 'Avviso Vocale
         End If
                  If ControlID$ = "butA" Then
            value = CStr(value) + "00"
            Enable =1
            Speak ("0 0") 'Avviso Vocale
         End If
         If ControlID$ = "butD" Then
            If InStr(1,value,".") = 0 Then
            value = CStr(value) + "."
            Enable =1
            Speak ("punto") 'Avviso Vocale
            End If
         End If
         If ControlID$ = "butB" Then
            value = Left(value,Len(value)-1)
            Enable =1
            Speak ("indietro") 'Avviso Vocale
         End If
         If ControlID$ = "butN" Then
            If Left(value,1) = "-" Then
               value = "+" + CStr(Right(value,Len(value)-1))
               Speak ("piu' ") 'Avviso Vocale
            Else
               If Left(value,1) = "+" Then
                  value = "-" + CStr(Right(value,Len(value)-1))
               Else
                  value = "-" + CStr(value)
                  Speak ("meno ") 'Avviso Vocale
               End If
            End If
            Enable =1
         End If
         If ControlID$ = "butDel" Then
            value = ""
            Enable =1
            Speak ("cancella ") 'Avviso Vocale
         End If
         If ControlID$ = "OK" Then
            Enable = -1
         End If
      Case 3 'Text verändert
         'MsgBox Dlg1.FText
      Case Else
   End Select
   'Wert zurückgeben
   If Enable = -1 Then
      Enable = value
   End If
End Function
Offline TPS
  •  2,627 2,627
Re: change virtual keyboard
« Reply #1 on: October 12, 2023, 03:53:29 AM »
Code: [Select]
' TAST ASSE X
Global CanButtonpressed As Boolean
Sub Main
   'declare variables
   Dim Pos As Double
   MinPos = -1000.0
   MaxPos = 1000.0
   DroNum  = 800
   CanButtonpressed = false
End Sub
'TPS 01.12.2017
'numerische Eingabe
   Dim title As String
   title = Header
      PushButton 65, 185, 40, 18,"Cancel", .CAN
   End Dialog
   x = Dialog( Dlg1 )
   If CanButtonpressed = false Then
   End If
End Function
   Select Case Action%
      Case 1
            Enable =1
         End If
            Enable =1
         End If
            Enable =1
         End If
            Enable =1
         End If
            Enable =1
         End If
            Enable =1
         End If
            Enable =1
         End If
            Enable =1
         End If
            Enable =1
         End If
            Enable =1
         End If
            Enable =1
         End If
            Enable =1
            End If
         End If
            Enable =1
         End If
            Else
               Else
               End If
            End If
            Enable =1
         End If
            value = ""
            Enable =1
         End If
            Enable = -1
         End If
         If ControlID$ = "CAN" Then
    CanButtonpressed = true
            Enable = -1
         End If
         'MsgBox Dlg1.FText
      Case Else
   End Select
   'Wert zurückgeben
   If Enable = -1 Then
      Enable = value
   End If
End Function
« Last Edit: October 12, 2023, 03:55:33 AM by TPS »
« Reply #2 on: October 12, 2023, 04:03:08 AM »
TPS thanks for your help, once again you solved my problem !!!!!!!!!! works well.
Greetings
