Hello Guest it is November 13, 2026, 03:02:00 PM
Author Topic: Out of control axis when using MPG  (Read 27961 times)
« on: October 04, 2023, 08:57:17 AM »
After weeks or troubleshooting and tons of support from Artruro Duncan, I have my lathe working, mostly.  Just one small issue I need some help with.
I can jog both axes using continuous mode and the X and Z + and - keys.  It works flawlessly.
But then I switch to MPG mode and move the handwheel even one click in either direction, the axis will run away.  I can't stop the motion except by hitting the estop.
What am I missing?
Huge shoutout to Artruro, BTW!  He has been great.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Out of control axis when using MPG
« Reply #1 on: October 04, 2023, 07:46:26 PM »
We need more details about the software and the control.
« Reply #2 on: October 05, 2023, 06:53:30 AM »
Graham,
This is my setup, please let me know if there is something else that would be helpful.  All of the boards and the MPG came from CNC4PC:
PC running Windows 7
2 Startech PCI parallel port cards.
Port 1 is connected to a C10 BOB which is in turn connected to two DM556 stepper drivers
I have two home switches wired in parallel connected to pin 15 on the C10.
Port 2 is connected to a C22 board, which is in turn connected to an MPG2 pendant.
In Mach3 I enabled port 2 and set pins 2-9 as inputs
  •  2,785 2,785
« Reply #3 on: October 06, 2023, 09:49:07 AM »
« Reply #4 on: October 06, 2023, 10:05:07 AM »
yes.   I think I know what is going on and I believe it is a problem with the parallel port card.  They have been troublesome all along.  As of this moment, and it could change, I believe I will buy a UC400ETH from CNCDrive and use that in place of the parellel cards.
« Reply #5 on: October 06, 2023, 01:29:14 PM »
upon further investigation it looks like the UC400ETH won't work for me because both ports are configured to be primarily output signals.  Instead I am looking into a Warp9 ESS, specifically the B-ESS.
