Hello Guest it is November 13, 2026, 02:13:44 PM
Author Topic: Probe not being detected Mach 3 Mill  (Read 29220 times)
« on: September 29, 2023, 09:40:01 PM »
Hi all,
I have a cncest 6040 Chinese router and would like to add a probe input.
I purchased this probe:
https://a.aliexpress.com/_mq7IfYi
And I have connected it to input #4 as shown in the manual:
https://shorturl.at/sDKU7
As per the instructions in the probe box, I connected red to 5V, black to GND and yellow to input #4.
The probe lights up and reacts to me touching it (Led is green until activated then turns red).
In ports and pins I have port set to 3, same as the input setup for emergency stop and pin set to 4.
Probe does not get triggered and I can't see any pins toggling when in the diagnostic window.
I'm out of ideas! What could I be missing??
Thanks in advance.
Re: Probe not being detected Mach 3 Mill
« Reply #1 on: September 30, 2023, 03:26:39 AM »
What do you mean by port 3?  Looks like your motion card is a USB type?  Or if parallel port maybe you should select port 1?
« Reply #2 on: September 30, 2023, 03:56:14 AM »
Yes it's USB. Sorry should have specified that.
