Hello Guest it is November 13, 2026, 03:01:44 PM
Author Topic: uc400eth fitted now motors judder  (Read 25366 times)
« on: September 12, 2023, 05:00:53 AM »
Just upgrade my cnc plasma cutter with a uc400eth from parallel ports BOBs etc. The problem I am having now is the X and Y axis judder when cutting. Still cuts the correct size etc but due to the judders the cut is now slightly serrated, and not good for the machine. Window 7, latest driver for the uc400. Mach3 up todate and of course licenced. All working fine before upgrade.
Any ideas, help etc gratefully received.
Steve
  •  9,377 9,377
Re: uc400eth fitted now motors judder
« Reply #1 on: September 12, 2023, 07:43:03 AM »
Are you perhaps running in Exact Stop mode rather than Constant Velocity mode ?
« Reply #2 on: September 12, 2023, 09:09:30 AM »
You sir are a steely eyed cnc man. Although it was in CV mode under the CV control check boxes Stop CV on angles was set to 0!
Many thanks for your help
Steve
