Hello Guest it is October 25, 2026, 04:37:52 PM
Author Topic: CNC Calibration: Circles Not Round  (Read 29650 times)
« on: September 10, 2023, 07:35:27 PM »
I'm a long time programmer but, completely new to cnc machining.  I have a homebrew 3 axis cnc router, but I'm unable to get round circles.  Here's what I'm seeing instead:
https://drive.google.com/file/d/1ZQ8s6cXgfiWKXvV0jc2hIqa1n8RjUfTP/view?usp=sharing
And here's the machine in action (if it helps):
https://drive.google.com/file/d/17-PwM5NcpHRFrbq4lnLBYUZ_5qPY7ml2/view?usp=sharing
Also, here's where I'm attempting to measure backlash:
https://drive.google.com/file/d/1_K-X9IH7ygsE3pvGv4LZB0IbhyUbAZRY/view?usp=sharing
Here's what I've tried so far:
* Calibration and adjusting motor setup
* Slowing the max machine speed down
* Measuring for backlash
I'm happy to try additional things but, given my inexperience I'm not sure what to try next.
Any suggestions would be greatly appreciated.
  •  9,374 9,374
Re: CNC Calibration: Circles Not Round
« Reply #1 on: September 10, 2023, 11:48:21 PM »
Just as a test...
Half your Velocity and Acceleration settings in Motor Tuning for each of your X and Y axis, saving the changes.
Do your circles now come out round ?
Offline TPS
  •  2,627 2,627
« Reply #2 on: September 11, 2023, 01:05:38 AM »
also make sure in Config -> General Config - Motion Mode -Exact Stop is selected
to measure backslash:
-jog axis tooward gauge
-zero gauge
-zero axis DRO
-now switch to handwheel mode single step and a small jog step (0,1 or 0,01)
-now jog axis away from gauge in single step's and watch gauge
-when gauge starts to move read your axis DRO to see your backslash
« Reply #3 on: September 11, 2023, 06:36:33 AM »
Thanks so much for the suggestions!  It's really nice to be able to get advice from experts.
Unfortunately, I am traveling to NYC for work this week but I will give both a shot next weekend and report the results.
« Reply #4 on: September 18, 2023, 08:22:41 AM »
I didn't get much time to work with the machine this weekend, but I did try the first suggestion.  I halved both the velocity and acceleration settings for both the X and Y axis.
Here's the result:
https://drive.google.com/file/d/1_pP5vEa1fsFVHLk5qdAgGGdQbXpwl_3N/view?usp=sharing
Maybe slightly more round, but overall still not super precise.
  •  9,374 9,374
« Reply #5 on: September 18, 2023, 09:08:26 AM »
Thats a terrible result & no good at all  :(
If your up for it, another test...
Tape a felt tip pen to your Spindle or Z axis. Will it now draw a round circle on a piece of paper or card ?
If it does then there is a mechanical issue with your machine, if it is still a bad circle then it could be related to your GCode or possibly a bad Mach setting somewhere.
Perhaps .zip and post a copy of your GCode so we can test it and also a copy of <your profile> .xml file (typically Mach3Mill.xml) from your Mach3 folder. The .xml file contains all your machine settings and we can test that they are correct or otherwise.
« Reply #6 on: October 17, 2023, 07:02:35 AM »
