Hello Guest it is October 16, 2026, 10:58:00 PM
Author Topic: Mach4 Hobby losing Tangential settings  (Read 25324 times)
« on: September 04, 2023, 08:31:23 AM »
Hi all that uses Tangential mode in Mach4!!
My machine running Mach4 Hobby in Win10 with a CSMIO/IP-A controller is losing tangential settings in the Tangential tab!  >:(
If I put the adjustments manually, they don't have any effect when restarting Mach4!
My output is being to replace the entire C:\Mach4Hobby folder with an old one!
Has anyone had this problem?!
Thank's in advance!
Offline smurph
  •  1,575 1,575
Re: Mach4 Hobby losing Tangential settings
« Reply #1 on: September 20, 2023, 11:54:39 PM »
I checked this and all of the tangential settings save correctly.  Are you running a recent build?
Steve
« Reply #2 on: September 22, 2023, 02:24:57 PM »
Hi Steve!
We are using Buil 4300
Version 4.2.0
Thank you!
Offline smurph
  •  1,575 1,575
« Reply #3 on: September 22, 2023, 02:45:43 PM »
Yeah, I can't even test that one.  We are on build 5199 at the moment.  You may need to upgrade.  :(
https://www.machsupport.com/ftp/Mach4/DevlopmentVersions/Mach4Hobby_Installer-4.2.0.5199.exe
Install it in a different directory and test it out first.  Then make sure you save you modifications (if you have any) to your screens and profiles before you upgrade completely.  There are some posts here on this forum somewhere that describe what you need to do when upgrading.
Steve
« Reply #4 on: September 22, 2023, 06:20:45 PM »
Ok Steve!
I will install, test and send you a feedback.
Thank you very much!
