Hello Guest it is November 19, 2026, 02:40:22 AM
Author Topic: doesnt mill the correct size  (Read 39136 times)
« on: August 27, 2023, 04:01:54 AM »
Hi All
Trying to mill a 5mm x 150mm slot, easy eh?  Well if I write the g-code manually it works, if I use V-Carve's output it comes out ~4mm x 149mm.  Code looks the same for both.  Thought about tool compensation but as far as I can see its not "active".  Stuck.  Machine is calibrated ok, using the correct 1/8" bit.  Help?
Example code attached as picture for comparison - left is working manually written, right is vCarve GCode mm arc's output - not working.
thanks!
James
Re: doesnt mill the correct size
« Reply #1 on: August 27, 2023, 03:34:35 PM »
Some of the math is skewing the results.
In the hand written code, the 1/8 inch bit is shown having a radius of 1.58
In reality 3.175/2 = 1.5875, or keeping the same precision 1.588
Also the X axis only seems to move 100mm, not the 150 mentioned.
In the generated code, X moves from -73.412 to +73.412 and adding the 2 radii of the bit adds up to 149.999mm
The Y moves from -0.913 to +0.913 adding in the bit again results in 5.001mm
As far as I can tell maybe your machine may need a little more adjustment.  Or measurement of the bit.
« Reply #2 on: August 30, 2023, 02:12:08 PM »
thanks for looking.
I checked the calibration and its fine at 40cm when jogged.
Edited the files to use the same numbers and I still get two different results, which I'll post if the forum page lets me! (third time writing this!)
Help?
« Reply #3 on: August 30, 2023, 02:15:07 PM »
« Reply #4 on: August 30, 2023, 02:15:34 PM »
ah.  code.  Left hand one gives 4mm, not 5mm :-(
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #5 on: August 30, 2023, 08:42:04 PM »
My guess is something is loose or slipping.
Offline TPS
  •  2,627 2,627
« Reply #6 on: August 31, 2023, 12:42:03 AM »
so, same coordinates but different speeds:
-loose or slipping like Graham mentoined
-loosing step's - devide your speed and acelleration in motortuning by 2
-G61/G64 setting - try to use G61
