Hello Guest it is November 13, 2026, 09:47:21 AM
Author Topic: spindle from MACH3 it always run a high speed  (Read 27213 times)
« on: August 16, 2023, 05:08:53 AM »
I followed all steps on this video (https://youtu.be/ehlgOhsmGAI), but when it try to run spindle from MACH3 it always run a high speed witch is I put on PD073, and I can decreasing it.
 can any one help me with that?
Re: spindle from MACH3 it always run a high speed
« Reply #1 on: August 29, 2023, 01:26:24 AM »
I followed all steps on this video (https://youtu.be/ehlgOhsmGAI), but when it try to run spindle from MACH3 it always run a high speed witch is Iangry granput on PD073, and I can decreasing it.
I used Mach3 V3.041 with a Smooth Stepper in PWM mode and the spindle override always started at a slightly higher speed than requested. Then, I pressed “Reset” under the Spindle Speed Tab and it worked. It brought the speed back to the correct requested speed. You can try this way.
« Reply #2 on: August 29, 2023, 02:57:21 AM »
Without more information on your hardware set-up and system configuration it's very hard to diagnose any problem!
