Hello Guest it is October 16, 2026, 07:36:10 PM
Author Topic: FIFO Drain Error  (Read 10068 times)
FIFO Drain Error
« on: July 26, 2023, 05:21:45 AM »
So I updated Mach4 setting up a new machine, and now all of the sudden my current machine won't run properly.
The motors will not respond/move.
If I restart Mach4 a hand full of times, they will finally respond.
As soon as I try homing, they move to the first or second switch.
At this point the machine stops and I get multiple pop-ups saying "HOMING_PREP failed waiting for FIFO to drain”.
Now nothing works again.
I have no idea what FIFO is.
Can anyone provide any ideas how to correct this issue?
Thanks in advance for any advice.
Offline ROTM
  •  24 24
Re: FIFO Drain Error
« Reply #1 on: August 04, 2023, 02:05:26 PM »
I have the same problem but some days it does it ...then some days it works good.
I get this error when trying to home.
I had done mutiple reinstalls(Windows and Mach4)...in the end replaced the computer that solved machine crashes, not doing tools changes and spindle not shutting down.
As I was explained to me this is a communication error.
so I have a new ESS board on its way that should take care of this problem...will update as the board is installed.(Next week)
Offline ROTM
  •  24 24
« Reply #2 on: August 11, 2023, 07:24:21 PM »
Board replaced same problem  ::)
« Reply #3 on: August 12, 2023, 05:17:58 AM »
« Reply #4 on: September 08, 2023, 05:43:17 AM »
« Reply #5 on: October 02, 2023, 02:32:17 PM »
The answer to all my problems was the version of Mach4 and the Warp9 plugin.
I uninstalled the latest versions and went through a list of older releases until I got the combination of build and version.
Everrything now works as it should.
I hope this helps out someone else as I was really fustrated with this.
Thanks everyone. :)
