Hello Guest it is November 22, 2026, 02:26:13 PM
Author Topic: A Axis  (Read 10253 times)
Offline lpz
  •  6 6
A Axis
« on: November 07, 2007, 12:50:25 PM »
How to convert "A" to degrees from Revolutions. EX. when my code = A1 ,my rotary head makes one complete revolution. I need the rotary head to move 1 degree when the code shows "A1", 360 degrees when "A" code =360.
Thanks for the help
LZ
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: A Axis
« Reply #1 on: November 08, 2007, 10:10:31 AM »
It sound as if you need to divide your 'steps per' by 360 in the motor tuning window.
Graham.
Offline lpz
  •  6 6
Re: A Axis
« Reply #2 on: November 08, 2007, 08:55:23 PM »
Thank you that worked. Now the next problem. The A axis is working properly as far as steps but it does not respone to the neg. value in the gcode that's running. It reads the line of code as if its always positive and doesn't go in reverse. I cant get a back and forth motion that's in the code created by protowizard.
Thanks again
LZ
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: A Axis
« Reply #3 on: November 09, 2007, 11:43:11 PM »
Hi, LZ
Under Config, General Config, Un-check the A 360 Rollover Box. and try this Gcode.
g90; ABS
g00 a10
g00 a-5
G00 a0
G91 ; INC
G00 a 10
G00 a-10
G90; ABS
M30
Hope this Helps, Chip
