Hello Guest it is October 21, 2026, 02:28:04 PM
Author Topic: ATC Y-axis won't go to negative value  (Read 6628 times)
« on: July 12, 2023, 09:38:07 PM »
Greetings!
I have an AvidCNC with auto tool changer. My tool rack is attached to the very front of the machine. To make room for the tool rack I moved the spoilboard forward to Y=434. I wanted the machine coordinates for the X and Y axis to be 0,0 at the spoilboard instead of at the front of the machine frame where the rack is attached so I offset Y-axis homing value to -434 such that when I home the machine Y=-434 instead of zero.
After doing so, when a tool change starts the Y-axis moves to +108.00 instead of moving to the assigned negative Y value to the rack that I assigned. No matter what negative Y value I assign to the tool it still goes to Y: +108.00 every time but the X and Z axis move to their intended positions.
I'd appreciate any assistance to make this work. Thanks!
« Last Edit: July 12, 2023, 09:53:43 PM by walkman »
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: ATC Y-axis won't go to negative value
« Reply #1 on: July 13, 2023, 04:52:41 PM »
Have you got soft limits turned on?
« Reply #2 on: July 13, 2023, 06:18:42 PM »
Yes, but the spindle does travel to all areas and works normally unless it is instructed to change tools. The problem exists only during an automatic tool change operation.
« Last Edit: July 13, 2023, 06:22:20 PM by walkman »
« Reply #3 on: July 14, 2023, 10:22:09 AM »
Could it be a case of "work coordinates" vs. "machine coordinates"?
Steve Stallings
www.PMDX.com
