Hello Guest it is October 11, 2026, 06:25:49 PM
Author Topic: Mach3 + ESS wrong settings?! HELP  (Read 32390 times)
« on: July 10, 2023, 02:55:51 PM »
Hi all, I have been working through some issues with my Cnc, have made some new discoveries and thought id see if anyone knows why I'm having this issue.
VIDEO OF PROBLEM - https://www.youtube.com/watch?v=38lDOMZstBk
I have ruled out the following...
Drivers
Cables
Connectors
Steppers
Binding
Computer (tried a different computer)
ethernet cord
Re: Mach3 + ESS wrong settings?! HELP
« Reply #1 on: July 10, 2023, 03:14:47 PM »
Here is my XML
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #2 on: July 11, 2023, 02:38:27 PM »
What control are you using, LPT, USB, Smoothstepper etc.
You have the A axis home and the probe on the same input.
If you are using LPT then with the settings you have set in the motor tuning you may be running out of steps at 25000Hz.
« Reply #3 on: July 11, 2023, 02:49:49 PM »
Sorry I didn't mention it has a ESS.
I will check on that input, I don't have a probe setup so not sure how that happened.
  •  2,785 2,785
« Reply #4 on: July 11, 2023, 02:57:16 PM »
Can you jog any single axis and it works as it should even if you hold down the shift key (Rapid Jog)
« Reply #5 on: July 11, 2023, 04:12:14 PM »
Yes I can jog and rapid jog one axis at a time (500ipm on X and Y, 187ipm on Z) no problem.
I think I may have found the problem, my BOB was outputting weird voltages for Dir and pul. Around 3.5v and -1.0 depending on direction...
« Last Edit: July 11, 2023, 04:19:50 PM by davidjamesi »
