Hello Guest it is October 21, 2026, 11:13:33 AM
Author Topic: Mach 4  (Read 5885 times)
Mach 4
« on: July 08, 2023, 11:28:08 AM »
I have purchased Mach4vHobby and using a WXHC Ethernet Motion card. I have my X axis running with 2 stepper motors ,Motor0 with Motor 3 slaved .The issue i am having is when i jog the x drive the readout on the Mach4 is correct minus goes minus and plus goes plus. The issue is on the Table its moving to the right i need it to move to the left. Everything i tried with reversing the pulse on the card and in the Mach4 program nothing changes .
Any help would be appreciated
thanks
Joe
joseph poirier
Offline thosj
  •  542 542
Re: Mach 4
« Reply #1 on: July 08, 2023, 02:11:36 PM »
There must be a plugin for your motion controller, right? Although I don't see one for Mach4. If you have one for Mach4 the setting will likely be in the config for the plugin.
« Last Edit: July 08, 2023, 02:14:37 PM by thosj »
Tom
Re: Mach 4
« Reply #2 on: July 08, 2023, 03:26:04 PM »
Thanks Tom i have looked in the config for the controller and there is a spot where is says to reverse the stepper motor and even though i do that nothing changes. So not sure if this needs to be changed in more than one spot .I will look again thank you for the reply.
Joe
joseph poirier
