Hello Guest it is October 21, 2026, 07:57:01 AM
Author Topic: Work with pen  (Read 24739 times)
Work with pen
« on: July 07, 2023, 07:12:45 AM »
Can I control the axle movement directly with the pen on the graphics display? Where and what settings should I ask? Thank you for your attention
  •  9,374 9,374
Re: Work with pen
« Reply #1 on: July 07, 2023, 10:55:49 AM »
Assuming you require accurate X and Y axis machine movement replicating the pen movement from a tablet…
There is no current facility for it to be done within Mach but it could be possible if the output from a graphics tablet was compatible with, just for example, the output from a CNC Pendant and suitable drivers were present.
Certainly an interesting possibility for anyone adept at writing the driver software plugin.
Re: Work with pen
« Reply #2 on: July 07, 2023, 12:57:39 PM »
Thanks for the reply. I realized that the task was quite difficult.
