Hello Guest it is November 11, 2026, 11:05:16 PM
Author Topic: Stop button Z move  (Read 125871 times)
Stop button Z move
« on: July 06, 2023, 05:28:10 AM »
Hello there.
I'm new here so please excuse any improper worded questions or wrong sub-forum.
Also I tried to search for an answer to this question for a while now and didn't even come close to an answer, so if this is a duplicate I'm sorry but I *tried*
To my Problem:
When I hit the "stop" button on the main screen of Mach3 the machine stops the X/Y movement after a short while, then stops the spindle and then it moves the Z-axis to what amounts to "G54 Z10".
This can be very dangerous in my use-case, since I regularly have to set the origin on the underside of my work-piece.
So when I have a piece that's higher than 10mm the machine will crash into the piece with a standing spindle.
To my question:
Is there a way to change this behavior and have mach3 move the Z-axis to for example "g53 z-1" instead?
Because right now I cannot use the "stop" button at all when I'm working with a higher than 10mm material, or I have to use the e-stop if something is fishy, which is not ideal either.
Thanks in advance :)
  •  9,377 9,377
Re: Stop button Z move
« Reply #1 on: July 06, 2023, 10:10:55 AM »
Try setting Config. / Safe_Z Setup
« Reply #2 on: July 07, 2023, 04:18:59 AM »
I must have stared at that menu for hours looking for exactly that and now that you said it's just right there :o
Thank you  :D
  •  9,377 9,377
« Reply #3 on: July 07, 2023, 04:52:00 AM »
