Hello Guest it is October 21, 2026, 03:31:32 PM
Author Topic: About m6  (Read 6522 times)
About m6
« on: July 06, 2023, 12:38:52 AM »
Hello.
I used the following "m6" that was on YouTube, but I would like to adjust the "tool setter: H = 31 mm".
"I did some research on my own, but I didn't understand."
Please someone tell me the solution.
problem
Line 46 returns to the machine coordinates of line 11.
After this, I want to correct "tool setter: H = 31mm".
1   :   function m6()
2   :   local inst = mc.mcGetInstance() ;
3   :
4   :    local currentTool = mc.mcToolGetCurrent(inst)
5   :    local selectedTool = mc.mcToolGetSelected(inst)
6   :    local posmode = mc.mcCntlGetPoundVar(inst, mc.SV_MOD_GROUP_3) --get the current mode so we can return to it when macro ends
7   :
8   :     --Get positions before moving to do tool change
9   :    local valX, rc = mc.mcAxisGetMachinePos(inst, mc.X_AXIS) --Get the position of the X axis in Machine Position
10   :    local valY, rc = mc.mcAxisGetMachinePos(inst, mc.Y_AXIS) --Get the position of the Y axis in Machine Position
11   :    local valZ, rc = mc.mcAxisGetMachinePos(inst, mc.Z_AXIS) --Get the position of the Z axis in Machine Position
12   :
13   :    if selectedTool == currentTool then
14   :     return
15   :     mc.mcCntlSetLastError(inst, "Current tool == Selected tool so there is nothing to do")
16   :    else
17   :
18   :     mc.mcCntlGcodeExecute(inst, "G90 G53 G0 Z0.0");--Move the Z axis all the way up
19   :     mc.mcCntlGcodeExecute(inst, "G53 X10 y0");--Move the X axis to the middle and Y axis to the end and
20   :     mc.mcCntlSetLastError(inst, "Change to tool " .. tostring(selectedTool) .. " and press start to continue") --Message at beginning of tool change
21   :     mc.mcCntlToolChangeManual(inst, true) --This will pause the tool change here and wait for a press of cycle start to continue
22   :     mc.mcCntlGcodeExecute(inst, "G53 G01 X10 y10 f350");--Move the X axis and Y axis to the tool setter
23   :     --mc.mcCntlGcodeExecute(inst, "G53 G0 z-2")--Moves the z axis down 5 inches rapid
24   :
25   :    mc.mcCntlGcodeExecute(inst, "g53 G31 z-4 f15")--Probes z axis to the tool setter
26   :     mc.mcCntlSetLastError(inst, "Current tool == " .. tostring(selectedTool) .. "   Previous Tool == " .. tostring(currentTool)) --Message that shows after Cycle Start
27   :     mc.mcToolSetCurrent(inst, selectedTool) --sets the current tool displayed in mach to the selected tool
28   :     --local probedzW = mc.mcAxisGetPos(inst, 2)  --This would give 0 axis (z on my machine) coordinates in work coordinate syste, ive shown it just for educational purposes
29   :     local probedz = mc.mcCntlGetPoundVar(inst, 5073) --this retreives the Saved varible of the z position (#5073) in machine coordinates and assigns it to the name probedz
30   :   local ToolLength =math.abs(probedz)  -- this calculates the value of the tool lenght by using a gage line off of my spindle to the tool setter.  uses the absolute value fuction
31   :     mc.mcCntlSetLastError(inst, "Tool Length" .. tostring(ToolLength))
32   :     mc.mcToolSetData(inst, mc.MTOOL_MILL_HEIGHT, selectedTool, ToolLength)  --- this sets the tool length value into the tool table into the selected tool position number, Note - i havent reassigned current tool varible so i have to use the "selectedTool" name
33   :     mc.mcCntlGcodeExecute(inst, "G04 p.5")
34   :     mc.mcCntlGcodeExecute(inst, "G90 G53 G1 Z0 F80") --Retract back to Z home
35   :
36   :     local MyChoice = wx.wxMessageBox("Remove Probe Clip","Click OK to continue" , 16)  -- brings up a dialog box and waits for a selection to proceed
37   :
38   :     if (MyChoice == 16) then  --16 is cancel
39   :         rc = mc.mcCntlSetLastError(inst, 'probing.')
40   :
41   :     return
42   :     elseif (MyChoice == 4) then
43   :
44   :     mc.mcCntlGcodeExecute(inst, string.format('G ' .. posmode))--return to pre macro mode G90, or G91
45   :     mc.mcCntlGcodeExecute(inst, "G90 G53 G0 X" .. tonumber(valX) .. "Y" .. tonumber(valY)) --Move back to X & Y initial location
46   :     mc.mcCntlGcodeExecute(inst, "G90 G53 G0 Z" .. tonumber(valZ)) --Move back to Z initial location
47   :
48   :     mc.mcCntlSetLastError(inst, "Tool Change Complete H ".. tostring(selectedTool) .. "   set to  ".. tostring(ToolLength).."  inches")
49   :   end
50   :
51   :   if (mc.mcInEditor() == 1) then
52   :    m6()
53   :   end
Re: About m6
« Reply #1 on: July 08, 2023, 05:48:57 AM »
After some trial and error, it worked.
There may be fixes as we proceed with testing.
Below is the preamble.
Thank you everyone.
1   :   function m6()
2   :
3   :   local inst = mc.mcGetInstance()
7   :
12   :
13   :   add
14   :   ----------- Get Work position --------------
15   :   --local StartPos = mc.mcCntlGetPoundVar(inst, ZVar);--Get a pound var value
16   :   local StartPos= mc.mcAxisGetPos(inst, mc.Z_AXIS)
17   :
18   :    if selectedTool == currentTool then
19   :     return
20   :     mc.mcCntlSetLastError(inst, "Current tool == Selected tool so there is nothing to do")
21   :    else
22   :
23   :     mc.mcCntlGcodeExecute(inst, "G90 G53 G0 Z0.0");--Move the Z axis all the way up
24   :     mc.mcCntlGcodeExecute(inst, "G53 X5 y0");--Move the X axis to the middle and Y axis to the end and
25   :     mc.mcCntlSetLastError(inst, "Change to tool " .. tostring(selectedTool) .. " and press start to continue") --Message at beginning of tool change
26   :     mc.mcCntlToolChangeManual(inst, true) --This will pause the tool change here and wait for a press of cycle start to continue
27   :     mc.mcCntlGcodeExecute(inst, "G53 G01 X5 y5 f350");--Move the X axis and Y axis to the tool setter
28   :     --mc.mcCntlGcodeExecute(inst, "G53 G0 z-2")--Moves the z axis down 5 inches rapid
29   :
30   :    mc.mcCntlGcodeExecute(inst, "g53 G31 z-4 f15")--Probes z axis to the tool setter
31   :     mc.mcCntlSetLastError(inst, "Current tool == " .. tostring(selectedTool) .. "   Previous Tool == " .. tostring(currentTool)) --Message that shows after Cycle Start
32   :     mc.mcToolSetCurrent(inst, selectedTool) --sets the current tool displayed in mach to the selected tool
33   :     --local probedzW = mc.mcAxisGetPos(inst, 2)  --This would give 0 axis (z on my machine) coordinates in work coordinate syste, ive shown it just for educational purposes
34   :     local probedz = mc.mcCntlGetPoundVar(inst, 5073) --this retreives the Saved varible of the z position (#5073) in machine coordinates and assigns it to the name probedz
35   :     local ToolLength =math.abs(probedz)  -- this calculates the value of the tool lenght by using a gage line off of my spindle to the tool setter.  uses the absolute value fuction
36   :     mc.mcCntlSetLastError(inst, "Tool Length" .. tostring(ToolLength))
37   :     mc.mcToolSetData(inst, mc.MTOOL_MILL_HEIGHT, selectedTool, ToolLength)  --- this sets the tool length value into the tool table into the selected tool position number, Note - i havent reassigned current tool varible so i have to use the "selectedTool" name
38   :     mc.mcCntlGcodeExecute(inst, "G04 p.5")
39   :     mc.mcCntlGcodeExecute(inst, "G90 G53 G1 Z0 F80") --Retract back to Z home
40   :
41   :     local MyChoice = wx.wxMessageBox("Remove tool Setter","Click OK to continue" , 16)  -- brings up a dialog box and waits for a selection to proceed
42   :
43   :     if (MyChoice == 16) then  --16 is cancel
44   :         rc = mc.mcCntlSetLastError(inst, 'probing.')
45   :
46   :     return
47   :     elseif (MyChoice == 4) then
48   :
49   :     mc.mcCntlGcodeExecute(inst, string.format('G ' .. posmode))--return to pre macro mode G90, or G91
50   :     mc.mcCntlGcodeExecute(inst, "G90 G53 G0 X" .. tonumber(valX) .. "Y" .. tonumber(valY)) --Move back to X & Y initial location
51   :     mc.mcCntlGcodeExecute(inst, "G90 G53 G0 Z" .. tonumber(valZ)) --Move back to Z initial location
52   :
53   :   add
54   :   local ZOffset =30.0 --Plate Hight
55   :   local ZZ = valZ - probedz + ZOffset
56   :   mc.mcAxisSetPos(inst,2,ZZ)
57   :
58   :     mc.mcCntlSetLastError(inst, "Tool Change Complete H ".. tostring(selectedTool) .. "   set to  ".. tostring(ToolLength).."  mm")
59   :     local MyChoice = wx.wxMessageBox("End of m6. Start OK?","Click OK to Start" , 16)
60   :   end
61   :
62   :   end
63   :
64   :   end
65   :
66   :   if (mc.mcInEditor() == 1) then
67   :   m6()
68   :   end
Re: About m6
« Reply #2 on: July 12, 2023, 01:47:44 AM »
partial fix
For m6, we found that the tool length is related to the Z-axis movement distance.
So I modified line 37.
Revised
Line 37: mc.mcToolSetData(inst, mc.MTOOL_MILL_HEIGHT, selectedTool, 0)
Also, thank you for all the access.
Re: About m6
« Reply #3 on: July 15, 2023, 01:49:07 AM »
Hello everyone.
In the Scripting Manual, ------------ Check Probe -------------
A script was written to check for probes.
It seems very useful, so I added it to this program.
If you have any good opinions, please post them.
