Hello Guest it is October 21, 2026, 10:17:53 AM
Author Topic: Build 4809 to 5153 Hobby, now with industrial look?  (Read 8897 times)
Offline FiveO
  •  19 19
« on: July 01, 2023, 09:48:23 AM »
Hi
upgraded from 4809 to 5153, and now I have industrial/darker gray look? How to switch to that original light gray screen look?
Offline thosj
  •  542 542
Re: Build 4809 to 5153 Hobby, now with industrial look?
« Reply #1 on: July 02, 2023, 08:52:06 AM »
Reinstall 4809, go copy the screenset out to somewhere, install 5153 and add the old screenset to it.
You COULD do this with directory renaming, too. Rename Mach4Hobby to Mach4Hobby_5153, install 4809 which will create a new Mach4Hobby directory. Copy the screenset you're interested in from 4809 install. Name folders back, Mach4Hobby to Mach4Hobby_4809, Mach4Hobby_5153 to Mach4Hobby. If you have other customizations, you will need to take those into account, too.
Tom
Offline FiveO
  •  19 19
« Reply #2 on: July 08, 2023, 11:55:30 AM »
Thank You!
Offline thosj
  •  542 542
« Reply #3 on: July 08, 2023, 01:02:23 PM »
NOW you may find your old screen isn't compatible with the 5000+ versions of Mach4. That's what I learned:)
Tom
Offline tantan
  •  130 130
« Reply #4 on: July 08, 2023, 01:45:39 PM »
version 5133????? i cannot find any version higher then 5036???
« Reply #5 on: July 08, 2023, 02:00:21 PM »
Version 5133 is a beta release. You can download it from here:
https://www.machsupport.com/ftp/Mach4/DevlopmentVersions/
Yes, development is actually mis-spelled, but the link is correct.  8-)
Steve Stallings
www.PMDX.com
Offline tantan
  •  130 130
« Reply #6 on: July 08, 2023, 02:04:02 PM »
aah, great thank you!
