Hello Guest it is October 09, 2026, 02:51:30 PM
Author Topic: Retract Z on feed hold or stop  (Read 24834 times)
« on: June 29, 2023, 05:36:04 PM »
When I use 'feed hold', 'stop' or 'reset', the machining stops right where it is and turns off the spindle... this is all good except I would like it to also retract the spindle height to a safe distance from the part... maybe 2in/50mm
I cannot find any setting to do this and if there is a problem such as needing to tighten stock clamps or even just cleaning away chips or lubing the bit, it really should immediately retract.... only exception would be E-stop, which is working fine.
Is there an option to cause a Z-Axis retraction on 'feed hold' or 'stop' in Mach3?
Offline TPS
  •  2,627 2,627
Re: Retract Z on feed hold or stop
« Reply #1 on: June 30, 2023, 01:18:52 AM »
Config -> Safe_Z Setup
« Reply #2 on: June 30, 2023, 09:27:40 PM »
ty ty i totally missed that, says right there "go to safeZ when stop button is hit"... it was at 0
