Hello Guest it is October 11, 2026, 07:08:01 PM
Author Topic: Lathe ATC turret VB  (Read 30608 times)
Lathe ATC turret VB
« on: June 29, 2023, 02:00:14 AM »
Hello.
Im currently retrofitting cnc lathe machine with 6 position turret. Controller is CS-labs.
Its stopped for me with vb script M6start. I just copied script text in it, checked atc in general config but after putting T1 M6m (T0101 M6) nothing happens , just a beep without any message. VB script go through without any warning.
How to solve this issue?
Greetings Nino
Offline TPS
  •  2,627 2,627
Re: Lathe ATC turret VB
« Reply #1 on: June 29, 2023, 03:50:14 AM »
without showing us your script it will be realy hard to help.
« Reply #2 on: June 29, 2023, 04:48:56 AM »
Hello.
This is code.
Code: [Select]
' CS-Lab s.c. - Auto toolchanger for lathe (rotary type of ATC)
' (C) 2011
' v1.2 - 2011-11-05
' CONFIG
Const OpenSensDelay = 800 ' Time Delay [ms] after ATC unlock
Const TimeLock = 1000 ' ATC locking time delay
Const TOOLCOUNT = 8 ' max Tool #
' Actual ATC position inputs (CSMIO-IP inputs)
Const InT1 = 16
Const InT2 = 17
Const InT3 = 18
Const InT4 = 19
Const InT5 = 20
Const InT6 = 21
Const InT7 = 22
Const InT8 = 23
' ATC sensors inputs
Const InOpenSensor = 25 ' ATC unlocked (rotating)
Const InCloseSensor = 24 ' ATC locked - safe
' digital outputs for ATC control (CSMIO outputs)
Const OutRun = 4 ' unlock and rotate
Const OutLock = 5 ' stop rotation and lock at current position
' program variables - don't modify
Dim ToolNew, ToolOld, ToolSlot As Integer
Dim ToolRdy As Boolean
Dim ATC_CloseRetry
Dim InToolSens(TOOLCOUNT)
  ' MACRO START
if(GetOEMLed(800)) Then
Message("System jest w trybie ESTOP - WYMIANA PRZERWANA")
Sleep(150)
WaitForMove
End
End If
  SetUserLED(1001, 1) ' User LED - toolchange in progress
  InToolSens(0) = InT1
  InToolSens(1) = InT2
  InToolSens(2) = InT3
  InToolSens(3) = InT4
  InToolSens(4) = InT5
  InToolSens(5) = InT6
  InToolSens(6) = InT7
  InToolSens(7) = InT8
' Get actual tool # and new tool #
ToolOld = GetCurrentTool()
ToolNew = GetSelectedTool()
' little trick for double slots ATC
If(ToolNew >= 10) Then
ToolSlot = ToolNew - 10
Else
ToolSlot = ToolNew
End If
If(ToolOld >= 10) Then
ToolOld = ToolOld - 10
End If
' The same position - no need to move
If (ToolSlot = ToolOld) Then
SetCurrentTool( ToolNew )
Message("ATC is on position "& ToolSlot & " and new tool is " & ToolNew)
WaitForMove
SetUserLED(1001, 0)
End
End If
If (ToolSlot > TOOLCOUNT) Then
SetCurrentTool( ToolOld )
SetUserLED(1001, 0)
DoOEMButton(1003)
DoOEMButton(1002)
Sleep(150)
Message("There is no tool T" & ToolNew & " in ATC")
Sleep(150)
End
End If
' T0 is a fake tool, no need to change
If (ToolSlot = 0) Then
ToolNew = 0
Message("Za³adowano narzêdzie nr: " & ToolNew)
WaitForMove
SetUserLED(1001, 0)
End
End If
' unlock and rotate ATC
RunATC
Sleep( OpenSensDelay )
' check ATC open sensor
If (Not GetCsmioIn(InOpenSensor)) Then
LockATC
SetCurrentTool( 0 )
SetUserLED(1001, 0)
DoOEMButton(1021)
DoOEMButton(1002)
Sleep(150)
Message("ATC locked - toolchange failed.")
Sleep(150)
End
End If
' wait to ATC will be on the desired position
ToolRdy = false
While(Not ToolRdy)
If(GetCsmioIn((InToolSens(ToolSlot - 1)))) Then
ToolRdy = true
End If
Wend
' stop rotation and lock ATC
LockATC
ATC_CloseRetry = 0
' Check lock sensor, retry lock if needed
While(Not GetCsmioIn(InCloseSensor) And ATC_CloseRetry < 4)
LockATC
ATC_CloseRetry = ATC_CloseRetry + 1
Wend
' double check for succesful ATC lock
If (Not GetCsmioIn(InCloseSensor)) Then
SetCurrentTool( 0 )
SetUserLED(1001, 0)
DoOEMButton(1021)
DoOEMButton(1002)
Sleep(150)
Message("ATC lock alert. Check ATC.")
Sleep(150)
End
End If
Message("Succesful loaded tool T" & ToolNew)
Sleep(150)
WaitForMove
SetUserLED(1001, 0)
End
Public Function GetCsmioIn (n As Integer) As Boolean
Dim reg As Integer
If(n < 16) Then
reg = 90
Else
reg = 91
n = n - 16
End If
If(GetInBit(reg, n)) Then
GetCsmioIn = true
Else
GetCsmioIn = false
End If
Exit Function
End Function
Sub RunATC ()
Call SetCsmioOut(OutLock, false)
Sleep(150)
Call SetCsmioOut(OutRun, true)
Sleep(150)
End Sub
Sub LockATC ()
Call SetCsmioOut(OutRun, false)
Sleep(150)
Call SetCsmioOut(OutLock, true)
Sleep(TimeLock)
Sleep(150)
End Sub
Public Sub SetCsmioOut (ByVal n As Integer, ByVal state As Boolean)
If(state) Then
SetOutBit(90, n)
Else
ResetOutBit(90, n)
End If
End Sub
Sub WaitForMove ()
While IsMoving()
Sleep(15)
Wend
End Sub
grettings Nino
Offline TPS
  •  2,627 2,627
« Reply #3 on: June 29, 2023, 05:13:03 AM »
are the in/outputnumber in the config aeria of the script corresponding to you hardware?
the script is for a 8 place ATC, you wher talking from a 6 place ATC.
how does your ATC hardware look like?
« Reply #4 on: June 29, 2023, 05:41:42 AM »
Its actually for 6 tools, im currently at work and i posted online version of script.
I changed only tool count to 6, deleted const int7 and 8 and set in&out pins to my setting.
Hardware is 6 poz rotary switch, lock sw NO+NC, motor fwd/rew and brake.
Electricaly everything works, i get every input and output correct.
As i mentioned, if i run vb , go through without errors. When i want to control it through mdi T1M6 nothing happens.
Greetings Nino
Offline TPS
  •  2,627 2,627
« Reply #5 on: June 29, 2023, 05:44:23 AM »
pls post the script you are using, if you are back home.
« Reply #6 on: June 29, 2023, 10:23:54 AM »
Hello.
Here is my code. It is connected trough csmio IO module , module nr0 (register 100).
Code: [Select]
'------------------------------------------------------------------------------ NINO_version_0
' (C) 2011
' v1.2 - 2011-11-05
' CONFIG
Const TOOLCOUNT = 6 ' max Tool #
Const InT1 = 0
Const InT2 = 1
Const InT3 = 2
Const InT4 = 3
Const InT5 = 4
Const InT6 = 5
' Const InT7 =
' Const InT8 =
Const InOpenSensor = 6 ' ATC unlocked (rotating)
Const InCloseSensor = 7 ' ATC locked - safe
Const OutRun = 0 ' unlock and rotate
Const OutLock = 1 ' stop rotation and lock at current position
Dim ATC_CloseRetry
  ' MACRO START
Sleep(150)
WaitForMove
End
End If
Else
ToolSlot = ToolNew
End If
End If
WaitForMove
SetUserLED(1001, 0)
End
End If
SetUserLED(1001, 0)
DoOEMButton(1003)
DoOEMButton(1002)
Sleep(150)
Sleep(150)
End
End If
ToolNew = 0
WaitForMove
SetUserLED(1001, 0)
End
End If
RunATC
LockATC
SetCurrentTool( 0 )
SetUserLED(1001, 0)
DoOEMButton(1021)
DoOEMButton(1002)
Sleep(150)
Sleep(150)
End
End If
ToolRdy = false
While(Not ToolRdy)
ToolRdy = true
End If
Wend
LockATC
ATC_CloseRetry = 0
LockATC
Wend
SetCurrentTool( 0 )
SetUserLED(1001, 0)
DoOEMButton(1021)
DoOEMButton(1002)
Sleep(150)
Sleep(150)
End
End If
Sleep(150)
WaitForMove
SetUserLED(1001, 0)
End
Dim reg As Integer
If(n < 16) Then
reg = 100
Else
reg = 101
n = n - 16
End If
GetCsmioIn = true
Else
GetCsmioIn = false
End If
Exit Function
End Function
Sub RunATC ()
Sleep(150)
Sleep(150)
End Sub
Sub LockATC ()
Sleep(150)
Sleep(TimeLock)
Sleep(150)
End Sub
If(state) Then
SetOutBit(100, n)
Else
ResetOutBit(100, n)
End If
End Sub
Sub WaitForMove ()
While IsMoving()
Sleep(15)
Wend
End Sub
Greetings Nino
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #7 on: June 29, 2023, 03:38:22 PM »
Lathes do NOT use T1 M6 they use T0101
Offline TPS
  •  2,627 2,627
« Reply #8 on: June 30, 2023, 01:15:22 AM »
made some changes, marked with TPS
Code: [Select]
' (C) 2011
' v1.2 - 2011-11-05
' CONFIG
Const InT1 = 0
Const InT2 = 1
Const InT3 = 2
Const InT4 = 3
Const InT5 = 4
Const InT6 = 5
' Const InT7 =
' Const InT8 =
Dim ATC_CloseRetry
  ' MACRO START
If(GetOEMLed(800)) Then
Sleep(150)
WaitForMove
End
End If
'TPS  InToolSens(6) = InT7
'TPS  InToolSens(7) = InT8
Else
ToolSlot = ToolNew
End If
End If
WaitForMove
SetUserLED(1001, 0)
End
End If
SetUserLED(1001, 0)
DoOEMButton(1003)
DoOEMButton(1002)
Sleep(150)
Sleep(150)
End
End If
ToolNew = 0
WaitForMove
SetUserLED(1001, 0)
End
End If
RunATC
LockATC
SetCurrentTool( 0 )
SetUserLED(1001, 0)
DoOEMButton(1021)
DoOEMButton(1002)
Sleep(150)
Sleep(150)
End
End If
ToolRdy = false
While(Not ToolRdy)
ToolRdy = true
End If
Wend
LockATC
ATC_CloseRetry = 0
LockATC
Wend
SetCurrentTool( 0 )
SetUserLED(1001, 0)
DoOEMButton(1021)
DoOEMButton(1002)
Sleep(150)
Sleep(150)
End
End If
Sleep(150)
WaitForMove
SetUserLED(1001, 0)
End
Dim reg As Integer
If(n < 16) Then
reg = 100
Else
reg = 101
n = n - 16
End If
GetCsmioIn = true
Else
GetCsmioIn = false
End If
Exit Function
End Function
Sub RunATC ()
Sleep(150)
Sleep(150)
End Sub
Sub LockATC ()
Sleep(150)
Sleep(TimeLock)
Sleep(150)
End Sub
If(state) Then
SetOutBit(100, n)
Else
ResetOutBit(100, n)
End If
End Sub
Sub WaitForMove ()
While IsMoving()
Sleep(15)
Wend
End Sub
« Reply #9 on: June 30, 2023, 01:48:05 AM »
Thank you for your help. I found a problem   ??? I was setting machine in mill profile with turn screenset instead in turn profile. I moved settings to turn and its started working.
#beginersproblems
Greetings Nino
