Hello Guest it is October 22, 2026, 05:11:02 PM
Author Topic: My own Plasma THC and Screen  (Read 5817 times)
« on: June 14, 2023, 12:25:11 PM »
I made the switch to Mach4 for my DIY plasma cutter - And after many hours of struggling with scripts and a lot of back and forth with Trevor I got my own THC working.  I must give credit to Mach4 since a lot of the inspired code is from the original mcTHC although it all has been rewritten.
Some changes i felt needed to happen from the original mcTHC -
- THC Adjustments rate cannot be set as a % of the max federate of a motor.  This does not translate across machines.  I changed this to be a % of the current XY Blend Velocity.  The faster I cut, the faster the torch can move.  Simply physics. I have added a dynamic mode that does take the voltage difference between target and current into account and adjust the thc rate quicker or slower.
- I removed the PID as this is too complex for general Plasma Operators, but also overkill for the small changes required.  I've replaced this with a static and dynamic option.
- Sampled Voltage - When the M5 macro complete, the system will measure samples and avg a target voltage.  You can specify the delay time, and samples to use.
- I changed the modes to only 2.  Manual and Auto.   If you enable auto, the system will switch from manual when ark ok and sample voltage completed. (If used)
- Anti Dive (Based on low feedrate) is always enabled.  M62/M63 gcode to stop THC is also added.  Thus you can cut slower with THC enabled.
-I've added 3 target voltage slots - Depending on the Requested Feedrate in Gcode, the target voltage is set.
Let me know if this is something you would like to try out..
« Last Edit: June 14, 2023, 12:30:06 PM by massynrt »
Offline Bill_O
  •  615 615
Re: My own Plasma THC and Screen
« Reply #1 on: June 14, 2023, 02:34:16 PM »
Very nice.
I don't do plasma so have no idea if what you did makes it better for others.
Better for you so that is all that counts.
