Hello Guest it is October 11, 2026, 06:46:55 PM
Author Topic: External noise causeing mach 3 to estop  (Read 24127 times)
Offline sn96
  •  60 60
« on: June 10, 2023, 12:49:55 PM »
Hello all,
I have a new issue and id like to hear your thoughts. Every time I press the motor stop button on my mill it causes mach3 to go into estop mode. there is no connection what so ever between the mill spindle and mach3, in fact, if I use my shop vac and then turn it off while in the middle of a cut, it will throw mach3 into estop mode! Apparrently the new motion card is getting spikes every time a power switch is turned off! Has anyone tried using a usb isolator to prevent this from happeneing?
Mike
________________________________
PM25mv with Arizona cnc conversion kit
windows 10
i7 laptop
mach3 demo latest version
stepperonline 566 ozin closed loop stepper 4.0 driver for x and y
stepperonline 1699 ozin closed loop stepper 4.0 driver for the z
amazon no name brand usb controller
Re: External noise causeing mach 3 to estop
« Reply #1 on: June 11, 2023, 04:11:05 PM »
USB is rather noise prone. An ethernet connection is less so, and that is because an ethernet connection has a small signal transformer at each end
whereas a USB does not. I have been told that there are USB cables that have signal transformers at each end and are more noise resistant. They are a non standard part
so I suspect you would have to aske specifically for one, and pay a premium probably, but might be worth a try.
