Hello Guest it is November 13, 2026, 05:04:38 PM
Author Topic: ESS Smothstepper & Triple Beast  (Read 74253 times)
« on: June 01, 2023, 05:04:13 AM »
Hello everyone.
I have a "cheese cutter" Karla with UC100 and Treaple Beast.
In the long term I would like to switch to the ESS Smoothstepper!
Question 1:
Can I buy the ESS Smothstepper first and use my UC100 (USB parallel adapter) as an Ethernet parallel adapter?
In the second step I would like to buy new drivers and stepper motors.
Is the?
Question 2:
Can I also use the ESS Smothstepper with Estecam?
Greetings
Ronald
Hallo zusammen.
Ich habe eine "Käsefräse" Karla mit UC100 und Treaple Beast.
Langfristig möchte ich auf den ESS Smothstepper umsteigen!
Frage 1:
Kann ich mir zuerst den ESS Smothstepper kaufen und meinen UC100 (USB-Paralell Adapter) als Ethernet-Paralell adapter verwenden?
Im zweiten Schritt möchte ich dann mir neue Treiber und Steppermotoren kaufen.
Geht das?
Frage 2:
Kann ich den ESS Smothstepper auch mit Estecam verwenden?
Grüße
Ronald
« Last Edit: June 01, 2023, 05:34:14 AM by Tweakie.CNC »
  •  9,377 9,377
Re: ESS Smothstepper & Triple Beast
« Reply #1 on: June 01, 2023, 05:34:51 AM »
The UC100 can be used as a ‘stand alone product’ with Mach3 but requires stepper drivers.
The Warp9 ESS can be used as a ‘stand alone product’ with Mach3 but requires stepper drivers.
The Tripple Beast can be used with Mach3.
You will need to contact Estlcam to ask Christian if the UC100 and Warp9 ESS are supported controllers.
« Reply #2 on: June 01, 2023, 07:26:46 AM »
Hello Tweakie,
thanks to your answer.
Mayby I didn't worte so that it is understandable.
I know that Smothstepper needs stepper drivers.
But:
can I replace my UC100 with the Smothstepper and use my Tripple Beast as Stepper Driver?
Regards Ronny
  •  9,377 9,377
« Reply #3 on: June 01, 2023, 11:14:35 AM »
As the output (Step, Direction, Etc.) from the UC100 is the same as the output from the ESS Smoothstepper then, if the Tripple Beast works OK with the CNC Drive UC100 then it will work OK with the Warp9 ESS Smoothstepper.
« Last Edit: June 01, 2023, 11:16:17 AM by Tweakie.CNC »
« Reply #4 on: June 01, 2023, 11:53:14 AM »
Thanks so much for your answer.
