Hello Guest it is October 19, 2026, 09:48:36 PM
Author Topic: mcSignalWait  (Read 9979 times)
mcSignalWait
« on: May 22, 2023, 12:42:34 PM »
 local dhs= mc.mcSignalWait(0, mc.ISIG_INPUT2, 1, 10);
                           hreg = mc.mcRegGetHandle(0, "iRegs0/break")
                             val = mc.mcRegGetValueString(hreg)
                             val = tonumber(val)
                             if(val==1) then
                              return 100
                                    end
                      if (dhs ~= 0) then--if not rise up in 10 second
end
atach one sample but there some that the single wait just not work
i cant say when  but in some cases its just run over ,not check the input and act like the input not ok without wait the second ordered
i think ill reaplace this function with simple loop that cheack input each...500 msec... or something like that
any coment?
Re: mcSignalWait
« Reply #1 on: May 22, 2023, 01:43:36 PM »
You don't make the wait signal a variable.
I use the mcSignalWait all the time on tool change macros.
Here is the example from the LUA Examples in the mach4 folder.
   local inst, hSig, rc
   inst = mc.mcGetInstance()
   hSig, rc = mc.mcSignalGetHandle(inst, mc.OSIG_OUTPUT1) -- Get handle for output 1
   if (rc~= 0) then --Check our return call
      mc.mcCntlSetLastError(inst, "There was an error")
   end
   rc = mc.mcSignalSetState(hSig, 1) --turn on output 1
   end
   rc = mc.mcSignalWait(inst, mc.ISIG_INPUT21, 1, 5) --Wait 5 seconds for input 21 to become active
   end
Chad Byrd
Re: mcSignalWait
« Reply #2 on: May 22, 2023, 03:09:27 PM »
you mean my mistake only because i use"local"?
i have in my m6 more then 5 inputs i need cheak ,and always i must give time out ,its cylinder need wait
and always i had problem
if my mistake is the decleraton "local "ill remove
thanks
Re: mcSignalWait
« Reply #3 on: May 22, 2023, 03:10:29 PM »
Yeah. That looks like all it is.
Chad Byrd
Re: mcSignalWait
« Reply #4 on: May 23, 2023, 07:32:43 AM »
sory i test also without ,not work
mny function that worked before maybi last version ui not sure
but all wait signal some times work some times m function ignore ...some stack real real disaster
Re: mcSignalWait
« Reply #5 on: May 23, 2023, 07:38:36 AM »
I would revert to the version that was working then and let NFS know there is an issue with the version you are having issues with.
Chad Byrd
Re: mcSignalWait
« Reply #6 on: May 23, 2023, 07:43:47 AM »
its complex becaus i play so much with all function ,i was so confused about this crazy beheivior until i found its all when  need wait
its not wait but continiue run ...
Re: mcSignalWait
« Reply #7 on: May 23, 2023, 10:46:29 AM »
I test again delete all my crazy test ,at the end you totally correct it's only this  "local" declaration ... thanks alot alot
Re: mcSignalWait
« Reply #8 on: May 23, 2023, 06:32:51 PM »
there was a time ,some five years ago now, where mcSignalWait did not work for signals with signal number above 64.
I think ISIG_INPUT64 is signal number 64 but ISIG_MOTOR1_HOME is signal number 66. At that time it did not work.
I think I manged to surprise smurph that it did not work.....and do believe that has been rectified, but it would pay to check.
