Hello Guest it is October 09, 2026, 03:23:54 PM
Author Topic: Quickly reload gcode at 0?  (Read 25705 times)
Offline ROTM
  •  24 24
« on: May 13, 2023, 05:26:04 PM »
Good day.
Question ..if I have a piece of material that is previously used.
Is it possible that if I zero where there is material to cut to quickly reload the gcode that I am using to the new zero position?
Thank you!
Re: Quickly reload gcode at 0?
« Reply #1 on: May 14, 2023, 02:19:25 AM »
Just move the cutter to the new zero, re reference the machine, and run the code.  It should anyway be rewound to the start.
Offline ROTM
  •  24 24
« Reply #2 on: May 14, 2023, 10:48:03 AM »
Got it...tnx
« Reply #3 on: June 11, 2023, 10:56:52 PM »
Please re-run the code to match the program
