Hello Guest it is November 13, 2026, 10:37:03 AM
Author Topic: Gearchange support Mach 3  (Read 23855 times)
« on: May 08, 2023, 06:16:08 PM »
Hi all.
I am just about to begin a conversion of A Deckel FP4ATC CNC from the late 80's.
I have figured out most of the requirements for the conversion however am undecided on 1 function. It has a gearbox controlled by 2 motors to allow for different spindle speeds. How would i be best to control this shifting inside mach3? I know it has been done in linux CNC using mesa cards to control the motors and a custom gearchange HAL however as i currently use Mach 3 on my converted round column mill I would like to continue to use what I know.
Thanks in advance.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Gearchange support Mach 3
« Reply #1 on: May 09, 2023, 05:40:24 PM »
The same way linuxcnc is doing it, the hardware is key, all that Mach3 will do is turn something on and off with M code macro.
Find out the details of the linux version and then report back with the details.
