Hello
Guest
it is
November 13, 2026, 09:59:13 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
closed loop
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: closed loop (Read 9764 times)
luther
8
closed loop
on:
November 04, 2007, 10:40:51 AM »
how do i set up a closed loop system in mach3 ?i went to used encoders with my steeper to make sure that i do not loose steps.
Logged
Carnoustie, Scotland
Re: closed loop
Reply #1 on:
November 04, 2007, 01:02:01 PM »
You will need one of the Encoder Interface boards that Ron Rogers sells
www.rogersmachine.net
It will not be true closed loop but Mach will halt if there is an error greater than the following error that you set.
Logged
Print
Pages:
1
Go Up
« previous
next »
