Hello Guest it is November 10, 2026, 01:39:11 AM
Author Topic: edit macro digits  (Read 13039 times)
edit macro digits
« on: April 08, 2023, 04:53:55 AM »
Good morning
I found this macro on the web, it works well, I kindly ask if anyone can modify it, since it is not in my skills and competences, the modification I would like to make is the following:
in the line " Open "C:\Mach3\SurfaceScan.txt" For Output As #iFileOutput " I would like if possible when saving if it finds a file with the same name that I store in "SurfaceScan1.txt .SurfaceScan2.txt , SurfaceScan3.txt, etc etc" I hope I made myself clear.
Thanks to anyone who can help me
Greetings
Code: [Select]
Option Explicit
Dim Xstart, Ystart, Zstart As Double
Dim Xdim, Ydim As Double
Dim Xpos, Ypos As Double
Dim Xcnt, Ycnt As Integer
Dim Xstep, Ystep As Double
Dim x, y As Integer
Dim FeedMeas, FeedMove As Double
Dim iFileOutput As Integer
FeedMeas=350
FeedMove=2500
Dim Title As String
Xdim=InputBox("Set scanning dimension in X",Title)
Ydim=InputBox("Set scanning dimension in Y",Title)
Xcnt=InputBox("Set number of samples in X",Title)
Ycnt=InputBox("Set number of samples in Y",Title)
If(Xcnt<1 Or Ycnt<0) Then
  MsgBox "Wrong parameters. Script terminated!",0,Title
  Exit Sub
End If
If(MsgBox("Start surface scanning?",4,Title)<>6) Then
  MsgBox "Script terminated!",0,Title
  Exit Sub
End If
ActivateSignal(OUTPUT4) 'aktivace digitizeru
If(Xcnt>1) Then
  XStep=Xdim/(Xcnt-1)
Else
  Xstep=0
End If
If(Ycnt>1) Then
  Ystep=Ydim/(Ycnt-1)
Else
  Ystep=0
End If
Xstart=GetOEMDRO(800)
Ystart=GetOEMDRO(801)
Zstart=GetOEMDRO(802)
For y=1 To Ycnt
  Ypos=Ystart + (y-1) * Ystep
  For x=1 To Xcnt
    Xpos=Xstart + (x-1) * Xstep
    Code "G90 G0 Z" & Zstart & " F" & FeedMove
    While IsMoving()
      Sleep(10)
    Wend
    Code "G90 G0 X" & Xpos & " Y" & Ypos & " F" & FeedMove
    While IsMoving()
      Sleep(10)
    Wend
    While GetOemLed (825) <> 0
      MsgBox "Sensor is active! Fix the sensor and continue.",0,Title
    Wend
   Code"G91 G31 Z-20 F" &FeedMeas
   Sleep(10)
   While IsMoving()
   Sleep(10)
   Wend
   Print #iFileOutput, "X" & roun(Xpos) & " Y" & roun(Ypos) & " Z" & roun(GetOEMDRO(802))
  Next x
Next y
While IsMoving()
  Sleep(10)
Wend
Code "G90 G0 X" & Xstart & " Y" & Ystart & " F" & FeedMove
While IsMoving()
  Sleep(10)
Wend
DeActivateSignal(OUTPUT4) 'aktivace digitizeru
Close #iFileOutput
