Hello Guest it is November 13, 2026, 09:37:46 AM
Author Topic: tool change stoped working  (Read 33558 times)
« on: April 03, 2023, 03:10:18 PM »
hey all i'm having issues with my machine when it calls a tool change.
everything has worked fine for years, the manufacture hasn't used mach for years and we are stuck.
we thought it mite be the grab bar sensors. i took the spindle off and took it to them to test. they took it apart and tested them and said they are working.
so i put it back together and changed the sensor wires from the spindle to the plc, and i still have the same problems.
****what it doing****
if i call for a tool change
1st: it goes and puts the in the tool holder
2nd: it releases the tool (but doesn't move z up) and gives me in the status bar (no characters found in reading real value, block=g00 g53 z)
there are 2 macros for m6   start and end
any idea?
Re: tool change stoped working
« Reply #1 on: April 03, 2023, 03:12:05 PM »
did my macros upload?
Offline TPS
  •  2,627 2,627
« Reply #2 on: April 04, 2023, 01:51:33 AM »
« Reply #3 on: April 04, 2023, 08:21:09 AM »
hope this works
Offline TPS
  •  2,627 2,627
« Reply #4 on: April 04, 2023, 08:23:24 AM »
« Reply #5 on: April 04, 2023, 08:25:30 AM »
hmm heres a link
https://drive.google.com/file/d/1OLBup09AaDK1dU-Q8-6DVkHGgeD3q5Zz/view?usp=share_link
ok i when through the startm1
i believe it has every thing to do with the
'Release tool and retract
  Label1:
  Call ActivateSignal (18) 'Open Tool Clamp
  Call ActivateSignal (16)      'Air Blast
  Sleep 2000 'Wait for clamp to activate
  While GetOemLed(1019) = 0 'Clamp LED - Clamp=on, Unclamp=off
  Wend
seems its that clamp led.
but i'm not sure what controls that
Offline TPS
  •  2,627 2,627
« Reply #6 on: April 04, 2023, 01:34:53 PM »
don't know witch motion controler you are using, but it look's like
the unclamped signal from your spindle, however this is made,
is not working.
a bit more info about the installed hardware would be helpful.
