Hello Guest it is October 22, 2026, 09:58:19 PM
Author Topic: I can't figure out why I get "A motor seems to be stuck backing off of a home"  (Read 5189 times)
Every time Mach4 starts I have this in the history even though they have not been touched:
Home switch Y Home tripped!
Home switch Z Home tripped!
And ever time I run the homing sequence I get these warnings over and over:
!!!!WARNING: A motor seems to be stuck backing off of a home switch! Check the diagnostics tab to see if the Home switch indicator is active when the switch is not!
But no motors are stuck and everything references fine.
Any ideas?
Lastly how do I chance how far the axis will back off of the home switch? My Y axis clears it but the X & Z tend to stay just enough on them to keep them triggered.
