Hello Guest it is November 13, 2026, 09:54:03 AM
Author Topic: emergency stop if the spindle falls on failure  (Read 24724 times)
« on: March 21, 2023, 01:45:17 PM »
are there settings in mach 3 that ensure that the machine stops if the inverter of the spindle jumps to failure i use a HY02D223B from haunyang because my spindle went into failure and the machine continued to run, my tapered ball nose of 90 euros broke off
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: emergency stop if the spindle falls on failure
« Reply #1 on: March 21, 2023, 04:57:45 PM »
Wire the VFD error output through your e-stop.
« Reply #2 on: March 22, 2023, 02:17:01 PM »
thanks for the quick reply but can you also tell me how to do that  i'm not that good in electronics field
