Hello Guest it is November 24, 2026, 06:08:24 PM
Author Topic: Mach 3 Jog distance  (Read 24498 times)
Mach 3 Jog distance
« on: March 15, 2023, 04:50:00 AM »
Apologies as I am quite new to Mach 3 coming from a Duet controller.
On the Duet screen I was able to jog the spindle precise amounts i.e. 50mm, 10mm, .5mm and .05mm from the control dashboard. Is this possible with Mach 3.
apologies if this is a very basic question?
Regards
M
  •  9,378 9,378
Re: Mach 3 Jog distance
« Reply #1 on: March 15, 2023, 05:14:15 AM »
Press the TAB key.
On the MPG flyout set the Cycle Jog Step you require. Select STEP in Jog Mode. Use the Jog Buttons to move any axis in increments of the step distance you have set.
« Last Edit: March 15, 2023, 09:19:12 AM by Tweakie.CNC »
« Reply #2 on: March 15, 2023, 09:53:40 AM »
Thank you Tweakie,
I thought there may be fixed selectable options (buttons so to speak).
I will have a play with that later
