Hello Guest it is October 25, 2026, 04:01:40 PM
Author Topic: Mach4 modbus issue  (Read 6388 times)
Mach4 modbus issue
« on: March 03, 2023, 12:28:51 AM »
Im trying to migrate working vfd modbus control from mach3 to mach4. However if I use the same register numbers, some get “Illegal data address exception response”
Read registers work fine. Write registers have this issue.
Im using Delta VFD-E. Troublesome registers are 2000H(control) and 2001H (frequency) (8192 and 8193)
Re: Mach4 modbus issue
« Reply #1 on: March 03, 2023, 02:22:35 PM »
there was/is a current thread which has an idea that you should investigate:
https://www.machsupport.com/forum/index.php?topic=47113.0
It concerns register addressing. Some installations number the registers 0,1,2,3......8192......etc whereas some others number them 1,2,3.....8192....etc.
There is a setting in the Mach4 Modbus plugin which allows you to select either protocol.
« Reply #2 on: March 05, 2023, 08:12:24 AM »
Thank you very much, it worked. im just going to mention, that it’s useful to restart mach4 between some modbus configuration changes.
