Hello Guest it is November 24, 2026, 06:38:33 PM
Author Topic: Mach 3 Spindle not starting  (Read 24463 times)
« on: March 02, 2023, 01:46:36 PM »
I recently tested the E-stop on my CNC and after doing so, the spindle will not start up. I am trying to debug but getting stuck. When I initiate the spindle, I get the yellow light for the 1 second dwell and then a green blinking light in the spindle speed area of the Program Run page. When I look at the diagnostic page, I get a red blinking light in the output (#2) where the Spindle output is set. I'm not sure if the Estop test actually did anything to cause this issue, but it's the only change I can think of since the last time I ran a program on there.
Any feedback would be appreciated.
« Last Edit: March 02, 2023, 01:49:21 PM by md12 »
Re: Mach 3 Spindle not starting
« Reply #1 on: March 06, 2023, 02:55:12 PM »
Adding images of the diagnostics and program run page
« Reply #2 on: March 07, 2023, 10:17:35 AM »
embarrassingly enough this was solved by unplugging the spindle power and plugging it back in.
