Hello Guest it is November 23, 2026, 04:51:28 AM
Author Topic: OEM Code for referencing wrong?  (Read 53963 times)
Offline Vido
  •  25 25
« on: February 28, 2023, 10:46:36 AM »
Hello, I have a list of oem codes that says the oem code for referencing the x-axis is 1022. If i click the referencing button under "edit button script" in Mach3, the code behind this button is displayed. However, this code says "DoButton(22)" and not "DoButton(1022)". The same applies to the other two axes. Is my list of OEM codes wrong?
Offline Vido
  •  25 25
Re: OEM Code for referencing wrong?
« Reply #1 on: March 01, 2023, 01:49:27 AM »
Referencing is independent of the machine type. The OEM code list I have is from Mach3 and this applies to milling, turning and plasma cutting.
