Hello Guest it is November 19, 2026, 01:50:02 AM
Author Topic: Post processor modification to set end location for cycle end  (Read 20366 times)
« on: February 25, 2023, 11:51:17 AM »
I have pored over my post processor, I cannot find where to modify it to do the following: end of cycle rise up all the way, go back 300mm.  Is this an easy mod, can it be done within Mach 4 apart from the post processor? I did attach the avid post processor.
Currently is makes this: "G0 Z15."  Id be happy with
"G0 Z80.
Y300"
Offline kf2qd
  •  157 157
Re: Post processor modification to set end location for cycle end
« Reply #1 on: March 22, 2023, 04:53:20 PM »
Is homing setup on your machine? If so, you need to set the position for G28. For instance - on mill mill I have G28 go yo Z Machine Home 0, Y machine home zero, and X -6.5 from machine home to put the table toward the front and centered.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #2 on: March 22, 2023, 05:58:31 PM »
Try this version :-
