Hello Guest it is October 24, 2026, 01:59:40 AM
Author Topic: New to Mach4, a few questions.  (Read 6353 times)
Offline Zaae
  •  120 120
« on: February 23, 2023, 05:45:58 PM »
Hi all,
Mach3 for a decade, now Mach4 for the last week.
1 - Is it possible to set up the built-in keyboard addon to control jog amount? For example, + and - keys to adjust from 1.000 to 0.001 in increments?
2 - With Mach3, I was able to configure the Xbox360 plugin to use the variable triggers to control the jog rate, but I don't find that to be available in the Mach4 version. If that's not part of the plugin, do you think it would be possible to add that functionality through LUA?
3 - What do *you* use for a controller? Keyboard & mouse, Xbox Controller, MPG Pendant, or something else? I've been using the Xbox360 plugin on Mach3 for years, but I'm willing to learn something new if #2 isn't an option.
Z
Re: New to Mach4, a few questions.
« Reply #1 on: February 26, 2023, 06:44:58 PM »
1) Yes, it is possible to code Mach such that a keystroke like '+' causes a macro to run and that macro could  'go to the next step of increment', that is the steps that you
set  up with Mach.
2) I don't know, the Xbox plugin was written by Daz-the-Gaz, you might you try asking him, or even better add that functionality to the plugin.....writing plugins
'puts hairs on your chest'.
3) I used a P1A VistaCNC pendant for seven years, and it was good. It had a setting to change the step increment for instance, but eventually it crapped out, or
rather I wore it out. Should have just bought a new one really, it was certainly good enough for so many years that it deserved replacement, but instead I made a wired
pendant. Has three axes,the MPG itself, and a Velocity jog button, the later one doesn't work as it should, but I've been using that for a year now always swearing
I'll get around to improving that....but never have. There is no more permanent thing than a temporary measure.
I use the pendant quite a bit but I don't find I need anything like all the functions crammed onto most pendants. For instance if I want a different jog increment I just use
Machs screen, I mean its right there after all. But my jog increment is set on either 0.1mm or 0.05mm and there it will stay for months at a time......and I use my mill a lot.
It's enough.
A pendant is to help you make parts....its not a toy to play with, and if its not a toy then it doesn't need to be complicated.
