Hello Guest it is November 11, 2026, 11:05:19 PM
Author Topic: Better card for mach 3 turn  (Read 112524 times)
« on: February 21, 2023, 12:19:01 PM »
Hi guys,
I am  new in here.I have used cnc lathe for  two months.My card is rnr motion (cheap red card).
I have a problem which is reading index signal  on same  time.Firstly  five pulse then  is true , but 6 ,7 .. signal are not equal time .Shortly, I do not see index clour changing on mach 3 screen.
Which am I use mach 3 card for mach3 turn?
I want to threading
 nice days
Re: Better card for mach 3 turn
« Reply #1 on: February 22, 2023, 01:19:13 AM »
UC100
« Reply #2 on: February 22, 2023, 07:00:56 AM »
UC100
is only running this converter?
another card or lpt port card on pc maybe?
« Reply #3 on: February 22, 2023, 07:17:47 AM »
Sorry, I don't understand what you are asking.  I use the UC100 card for my lathe with Mach3 if you want a recommendation.
If you are asking what might be wrong with what you have, from the description it may be that the debounce time is wrong.  What sort of spindle sensor do you have?  What is the debounce tine set to?
« Reply #4 on: February 22, 2023, 09:12:37 AM »
I am sorry that I can not tell it which ıI do not know uc100
really do you use threanding on mach3
my debounce time 50 , index debounce 10
my sensor is njk 5002c
I want to use spindle 150 rpm for threading
« Last Edit: February 22, 2023, 09:14:50 AM by erdem55 »
« Reply #5 on: February 22, 2023, 09:19:32 AM »
And what is the sensor picking up?
https://cncdrive.com/UC100.html
« Reply #6 on: February 27, 2023, 05:22:53 AM »
Hi, I did ne system with old lpt port , BUT  I have same problem.
Mach3 system too slow rpm reads index pulse like 30 rpm.
what is my problem?
« Reply #7 on: February 27, 2023, 05:45:09 AM »
The sensor photo you showed is a hall effect device.  You must have attached a magnet to the spindle for it to pick up - a photo of that would help.
Your spindle debounce is 1 x 40 us but the other debounce is set to 50  x 40 us which is 2 seconds!  Seems a bit long to me.
« Reply #8 on: February 27, 2023, 09:01:11 AM »
You are right that so long time debounce time
I turned it that is 5 or 200us
I do not use encoder ,what if do it create a problem ?
At the moment, index signal mix usb port like mouse that is not right
« Reply #9 on: February 27, 2023, 11:03:47 AM »
The index signal from that Hall sensor needs to be connected into the index input on the interface card and provide one pulse per revolution of the spindle.  To generate that pulse you need a small magnet on the spindle and the sensor needs to be mounted quite close to it (probably a mm or so) to pick it up.  Unless you provide the index pulse you will not be able to either indicate spindle rpm or do threading.  So what is your sensor picking up?
