Hello Guest it is October 24, 2026, 05:02:41 AM
Author Topic: Keyboard short cuts & editing current Gcode  (Read 14549 times)
Re: Keyboard short cuts & editing current Gcode
« Reply #10 on: February 19, 2023, 07:46:11 PM »
yes that Window has tabs, if you are not on FileOps tab then you wont see <GcodeEdit>
One of the things I disliked about Mach3 was that so much was squeezed into every screen, it was cluttered an confusing. Mach4 is still pretty jam-packed
but you can delete or supress anything that you don't want and de-clutter the screen considerably.
You probably have not tried it yet but you can make your own tab, like those along the top, like ProgramRun, MachineDiagnostics, etc. When you do you will find you can have
entirely your own screen, just as a tab within a bigger screen set. So when you do yet another of your bread & butter water pump jobs or whatever you just click on the tab
and all the relevant data, WCS, tool data and everything you need for that job is all on one tab....great.
« Reply #11 on: February 19, 2023, 08:09:13 PM »
Thanks!
Once I get things working properly I will be modifying the screen.
I am surprised that there are so few screens available.
The Newfangled site has a manual lathe, a manual mill,  and a CNC coil winder screen.
Presumably I am looking in the wrong area.
Bertho
