Hello Guest it is November 07, 2026, 10:41:52 AM
Author Topic: LazyCam 2.58 Arc End Rapids  (Read 14107 times)
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« on: November 01, 2007, 11:08:19 PM »
Hi. Art & Brian
Looks Like the fix is in for the Arc's turning to circle's.
As for the Arc's Rapids changing End's when moved, There's a little more work to be done, It's almost there.
1 Lset file below.
Thanks, Chip
« Last Edit: November 03, 2007, 01:40:24 AM by afn09556 »
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: LazyCam 2.58 Arc End Rapids
« Reply #1 on: November 02, 2007, 08:12:19 AM »
Hi Chip:
 Thats actually normal, as the arrow shows, its being told to move in that direction, so it woudl do only a very short move, then have to go back to the beginning, youd have to reverse direction with climkb milling to get the rapids back to the other side.. I did fixx the others, Ill add a check to see if we can do something with that as well to make it automatic..
Art
Offline Chip
  •  2,055 2,055
« Reply #2 on: November 02, 2007, 04:18:21 PM »
Thanks. Art & Brian
Looks like I may have jumped the gun a little, Worked on it for awhile though yesterday.
The default back to "Outside Right" was giving me a real bad time.
The "Ill add a check to see if we can do something with that as well to make it automatic..", Would be Nice !!
If LazyCam could open up in Auto Lead Configuration or stay in the same lead-in configuration you set after open-up and not default back to "Outside Right" every time, Would Help !!.
Thanks Again for these Great Programs, Chip
« Last Edit: November 02, 2007, 10:45:38 PM by afn09556 »
Offline Chip
  •  2,055 2,055
« Reply #3 on: November 02, 2007, 11:09:44 PM »
Hi. Art & Brian
Is there a current list of Post options for Lathe, Mill and Plasma, or a list for the Default Post.
Thanks, Chip
Offline Chip
  •  2,055 2,055
« Reply #4 on: November 03, 2007, 04:59:31 PM »
Hi. Art & Brian
This is what I have been trying to do, Use a DXF and LC's lathe post only to generate a lathe g-code file.
It's working now, Thanks to the fixes in Arc end points.
1 Lset below 1 txt
Thanks, Chip
« Last Edit: November 03, 2007, 05:33:31 PM by afn09556 »
Offline Chip
  •  2,055 2,055
« Reply #5 on: November 04, 2007, 02:16:40 AM »
Hi. Art & Brian
What I was thinking a 90 deg offset that starts at Origin Marker bottom right for inside cut's and top right for outside cut's, Origin Marker being your 0,0 start point, Using cutter\tool width as normal.
Until Lathe has a Chance to Mature
1 Lset below
Just Thinking , Thanks, Chip
