Hello Guest it is October 19, 2026, 07:02:51 PM
Author Topic: Mach3 M98 ignored  (Read 44280 times)
Mach3 M98 ignored
« on: February 15, 2023, 06:08:13 AM »
Hello,
I have a problem with M98 subroutine in Mach3.
If I run this gcode file:
Code: [Select]
G90
F2000
G1 Z -1
G1 X0 Y0
G91
M98 P1000 L4
M30
O1000
G1 Y200
G1 X200
G1 Y-200
G1 X-200
M99
the O1000 is never executed. When running in step by step mode, when the M98 line is focused, next step is M30 and not O1000.
If I wrote a second gcode file (1000.tap) and put it in the subroutine folder like this:
Code: [Select]
G1 Y200
G1 X200
G1 Y-200
G1 X-200
M99
and call it inside the main gcode file:
Code: [Select]
G90
F2000
G1 Z -1
G1 X0 Y0
G91
M98 (1000.tap) L4
M30
It works.
I try with .066 .062 and .043 version and it doesn't change anything.
Do you know where does come this problem? I haven't found answer on internet.
Thank you
jeff
Re: Mach3 M98 ignored
« Reply #2 on: February 15, 2023, 07:40:31 AM »
Thank you JohnHaine,
I already read this post and it doesn't work with subroutine program within the current part program file (separated subroutine in another gcode file works).
« Reply #3 on: February 15, 2023, 10:09:59 AM »
Here is some code (actually for knurling with a rotary axis) which I know works.
G00 X1 Y0 Z67.595
G91
G00 A5
F100
G01 Z-1.397
M98 p2000 L37
G00 X1 Y0 Z67.595
G90
o2000
G91
G01 X10.783 A97.297
G01 X-10.783 A97.297
M99
The main difference I can see is that the "o" in o2000 is lower case.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #4 on: February 15, 2023, 05:58:17 PM »
Try it like this :-
G00 X1 Y0 Z67.595
G91
G00 A5
F100
G01 Z-1.397
M98 p2000 L37
G00 X1 Y0 Z67.595
G90
M30
o2000
G91
G01 X10.783 A97.297
M99
« Reply #5 on: February 15, 2023, 11:33:30 PM »
Thank you JohnHaine and Graham,
I try your gcodes with lower cases P and O but it doesn't change anything. I try with a fresh install of Mach3 .062 without any personal setup on a virtual machine and it dosen't work.
Is there a way to put Mach3 in debug mode to get log?
jeff
« Reply #6 on: February 16, 2023, 05:55:54 AM »
I post a video on youtube to show you the problem:
https://youtu.be/jWNtcMbCoAU
jeff
« Reply #7 on: February 16, 2023, 11:07:35 AM »
Whenever I use M98 and M99 I have always added an M30 (and % on a new line) at the end of the program after the M99 in addition to  the one after the M98
grayhil
« Reply #8 on: February 16, 2023, 11:13:04 AM »
Well I just tried it in simulation and it worked fine v03.422
« Reply #9 on: February 16, 2023, 12:40:54 PM »
Thanks you,
I try to add M30 and % at end of file but it doesn't change anything. I will try with 3.422.
Thank you
Jeff
