Hello Guest it is November 13, 2026, 04:44:18 PM
Author Topic: Relay on at start up  (Read 31258 times)
« on: February 14, 2023, 03:03:47 PM »
I have a pokeys57cnc board and you must first turn on that machine before loading Mach4.  My coolant relay automatically is activated when I start the machine and then when Mach4 finally loads Mach4 turns it off.  How do I get it to not turn on automatically?
TIA
RT
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Relay on at start up
« Reply #1 on: February 14, 2023, 05:08:04 PM »
You get mach to enable a relay that switches the main power on the machine.
« Reply #2 on: February 14, 2023, 05:12:14 PM »
Maybe I'm misunderstanding you Graham.  I can't have Mach4 run a relay without a board and mach wont connect to the pokeys board unless it is already powered.
  •  2,785 2,785
« Reply #3 on: February 14, 2023, 05:17:09 PM »
Pokeys turns on a relay that turns on the machine main power pokeys can be powered by a small psu of its own.
