Hello Guest it is October 24, 2026, 12:02:11 PM
Author Topic: hello there - help please, how do you do the light sensor limit switch - 3 wires  (Read 65337 times)
Offline MN300
  •  306 306
Sorry to disappoint you but 2.2.8 shows the inputs expect a connection to 12V, not to ground like many breakout boards.
The sensor you have chosen will not work with this type input. Perhaps Omron makes a version with the same physical dimensions that has the right electrical features. I take a look.
oh, and you're welcome
Offline MN300
  •  306 306
A quick look gave no results from Omron, you'll have to widen the search. Probably you will have to make a new mount to fit what you find.
The correct sensor needs to run on 12V input power and have a PNP transistor output, Also the output needs to turn on when the light is blocked.
Post a part number if you find a likely candidate.
Offline nobby
  •  154 154
AHH,
So fudge some 12v limits for now.
Then get the ess smoothie, with 5v I/o and a 5v I/o Bob, hook that to them in the future when fitting to be e 200w servos.
Great idea
