Hello Guest it is October 24, 2026, 12:02:19 PM
Author Topic: hello there - help please, how do you do the light sensor limit switch - 3 wires  (Read 65338 times)
Offline nobby
  •  154 154
https://docs.rs-online.com/82f4/0900766b812c8e16.pdf
10v
not worth the risk?
pardon my ignorance, but i dont undestand 10v in and 28v out
Offline nobby
  •  154 154
its all a bit nice and stock with them
hmm
its a lovely machine, i have already bodged the motors on....
Offline MN300
  •  306 306
The input voltage powers the photosensor. The maximum voltage is 10V. However 5V is all it requires.
The output uses an open collector transistor that acts like a normally open contact to ground, just like a mechanical switch. The maximum voltage it can withstand is 28V.
There are many low cost voltage regulators on eBay, Here is one example.
https://www.ebay.com/itm/403714437758?
You can use it to reduce your 12V to 5V for supplying the photo sensor.
This one's output is set by two areas marked A and B where you blob two pads together with solder.
There is a chart to show you how to set the voltage. For 5V there's no blob on A and a blob on B.
Offline nobby
  •  154 154
hello
i have six of them 2 on each axis
can i get one of these
12v in red to 12v on nvem breakout board, black to ground
5v 3a out
yellow to pin 1 vcc on all 6  sensors
black to ground on all six sensors
then simply take vcc out
x axis x++ and x--
y axis y++ and y--
z axis z++ and y--
in mach have the same pin for both switches on the same axis
send it to home whichever way
thanks
Offline nobby
  •  154 154
thinking about it, i crashed my last machine a lot on soft limits - not having any travel after the switch
rookie mistake I hasten to make again
Offline MN300
  •  306 306
Yes you can power all the sensors with one supply, its 3A output is enough for 100 30mA sensors.
x axis x++ and x--
y axis y++ and y--
z axis z++ and y--
I'm not sure what you mean by vcc out, do you mean the output of the sensor? It's not Vcc, The output just makes a connection to ground when on.
You can connect two of these outputs to one input. The input needs to be the type that works with a switch contact to ground
Offline nobby
  •  154 154
ahh
so there is no ground for it as its used to step the 12 volts down to 5
so it is impossible
-great
2 wire limit switches
keep it simple
overtravel 10mm for soft limits
Offline MN300
  •  306 306
This is what I think you are asking for, two switches from the same axis connected to one input
Offline nobby
  •  154 154
12v out
input pin x axis ++ -- limit
ground
i can take the 12v  and the ground on the controller step that down to 5v and use the ground for the returning 5v to ground
the ground pin can be used for both 12v and 5v was confusing me
-or it isnt possible?
I am a novice
« Last Edit: February 09, 2023, 03:07:40 PM by nobby »
Offline nobby
  •  154 154
oh, and thank you
