Hello Guest it is October 24, 2026, 02:59:05 AM
Author Topic: Reading spindle true RPM  (Read 18434 times)
Offline Azalin
  •  191 191
« on: January 28, 2023, 11:55:09 AM »
Please see the video first.
I have no idea what happened but this was working before. Now the spindle RPM jumps while running.
Machine is a mill. Spindle is a servo. I confirm the servo drive shows the RPM correctly.
But interestingly when I speed up the spindle the range of the jumping numbers narrows. I mean it gets more stable. But slower RPMs are messy.
What could cause this?
https://www.youtube.com/watch?v=1tqyhtybhPc
« Last Edit: January 28, 2023, 12:01:04 PM by Azalin »
Re: Reading spindle true RPM
« Reply #1 on: January 28, 2023, 03:02:09 PM »
what motion controller are you using?
Motion controllers report back to Mach4 every 25ms or so, 25ms being the default cycle time of an ESS. At each cycle the motion controller will report
the number of spindle revolutions and Mach does the calculation. The problem is that the 25ms cycle time is nominal only, it might be 23ms sometimes
and 28ms at other times, with consequent variance of the calculated rpm. In most cases the displayed number is averaged. I would guess that somehow
the averaging strategy has changed.
Offline Azalin
  •  191 191
« Reply #2 on: January 28, 2023, 03:06:38 PM »
Motion controller is Pokeys 57E on M16D. I didn't play with Pokeys settings for months.
« Reply #3 on: January 28, 2023, 03:15:21 PM »
I doubt that anything has changed in the PoKeys, I asked so I could find out what the cycle time was.
I suspect if there is a change it will be in Mach4. If  I recall there is a post on the forum which talked about the averaging applied to the spindle speed DRO,
haven't had any luck finding it so far.
The two things which could affect the DRO in the manner that you have described are 1) the motion controller cycle time is changing, maybe some other process or software
on the PC assuming priority that is causing the motion control plugin to run at odd intervals, 2) the averaging applied to the numeric data has somehow altered.
Offline Azalin
  •  191 191
« Reply #4 on: January 28, 2023, 03:41:06 PM »
I'm writing a module for my Arduino based pendant but it's just an external .lua file.
Which parts in Mach4 I can check to see if I can fix?
« Reply #5 on: January 28, 2023, 04:02:06 PM »
At this stage, I don't know, I'm still trying to find the post about it. I'm hoping someone may remember and chime in.
Offline Azalin
  •  191 191
« Reply #6 on: January 28, 2023, 04:11:56 PM »
Is this the thread you are looking for?
https://www.machsupport.com/forum/index.php?topic=35694.0
« Reply #7 on: January 28, 2023, 04:43:34 PM »
Hi Azalin,
I remember hat thread, it was a few years ago now, but no that is not the thread I was thinking of.
If I recall correctly there is a setting, I believe within Mach, that governs the time constant of the averaging algorithm
displaying the spindle rpm.
Offline Azalin
  •  191 191
« Reply #8 on: January 29, 2023, 08:50:16 AM »
It's ok Craig.
This is really odd. I played with the numbers in both Mach4 and PoKeys. Nothing worked.
https://www.youtube.com/watch?v=3kztXPBJ3bs
Edit: There is an encoder test screen in PoKeys config app. When I spin the spindle the spped calculation appears to be correct so I think the problem is in Mach4.
« Last Edit: January 29, 2023, 08:52:51 AM by Azalin »
Offline Azalin
  •  191 191
« Reply #9 on: January 29, 2023, 10:47:44 AM »
Hi Craig,
https://www.machsupport.com/forum/index.php?topic=42282.0
Is this the one?
Hi Azalin,
