Hello Guest it is November 11, 2026, 11:05:23 PM
Author Topic: mach4 lathe threading  (Read 51245 times)
« on: January 21, 2023, 01:08:58 PM »
mach4 hobby version 2- 4612, win 10 home 64 bit.
I have a problem with threading -  missing steps in a random fashion on z axis so I suspect that the index has a fault but x also misses steps in the same random fashion while running the program. Can anyone confirm that x axis is also using the index to regulate the movement. The machine works perfectly with no missing steps when just turning something and when threading the g00 moves are happening as you would expect with no hangup.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: mach4 lathe threading
« Reply #1 on: January 21, 2023, 08:05:27 PM »
Have you got a clean index signal, X and Z use the index so taper threads can be cut.
« Reply #2 on: January 22, 2023, 01:07:41 PM »
The index is confirmed as faulty and my thanks to Graham who reminded me that you need an index for both axis as you can taper turn. Now to check what failed !!
