Hello Guest it is November 10, 2026, 01:39:11 AM
Author Topic: edit macro file  (Read 11912 times)
edit macro file
« on: January 21, 2023, 05:29:06 AM »
hello, I have this macro (found on the net) to import files, since it is not within my capabilities and skills, I ask if anyone can correct it for me. what I would like to do is this: in addition to selecting the file, I would also like to choose the directory (the line is = PathName = "c:\mach3\quilting") I have 7 different working directories and I would like to choose the directory where to download the file. is it possible to change it? Is there anyone who can help me? I hope I explained myself and I thank anyone who can help me
I attach macros
Code: [Select]
' Pattern File selection
Option Explicit
Global fileName As String
Global fileExitCode As Integer
Global fileExtension As String
Declare Function GetDlgCtrlID Lib "User32" ( ByVal hwndCtl As Long ) As Long
Declare Function DlgDirListA Lib "User32" ( ByVal hDlg As Long, ByVal PathSpec As String, ByVal nIDListBox As Long, ByVal nIDStatic As Long, ByVal nFileType As Long ) As Long
Sub Main
  fileExtension = "*.tap" ' the extension we are looking for
  Call GetFileName ' as user for file name
  If Len(fileName) = 0 Then ' if 0 len cancel
      fileExitCode = 1
  End If
  If fileExitCode = 0 Then
      MsgBox("The Selected Pattern is: " & fileName)
      SavePatternName ' save the name for others
      SetUserLabel(8, fileName) ' Set the user label for all to see
  Else
      MsgBox("No Pattern Selected")
  End If
End Sub
Sub GetFileName
    Dim MyList$()
    Begin Dialog PatternDlg 60, 60, 180, 225, "Quilt Pattern Select", .DlgFunc
        TextBox 10, 15, 150, 12, .Text1
        Text 30, 45, 150, 9, "", .Path
        Text 15, 5, 150, 9, "Selection Criteria"
        Text 35, 35, 150, 9, "Selected Pattern"
        ListBox 25, 60, 125, 140, MyList(), .List1, 2 ' Sort
        CancelButton 42, 203, 40, 12
        OKButton 90, 203, 40, 12
    End Dialog
    Dim frame As PatternDlg
    Dialog frame
End Sub
Function DlgFunc( controlID As String, action As Integer, suppValue As Integer )
    Static nPathID As Integer
    Static PathName As String
    Static nListID As Integer
    Static FileSpec As String
    Select Case action
    Case 1 ' Initialize
        DlgText "Text1", PathName & "\" & fileExtension
nListID = GetDlgCtrlID( DlgControlHWND("List1") )
nPathID = GetDlgCtrlID( DlgControlHWND("Path") )
        DlgDirListA DlgHWND, DlgText("Text1"), nListID, nPathID, &h10
    Case 2 ' Click
        If controlID = "Cancel" Then ' Cancel Button
            fileName=""
            fileExitCode=1
            DlgFunc = 0
            Exit Function
        End If
        If controlID = "OK" Then ' OK Button
            PathName = DlgText("Path")
            fileExitCode=0
            DlgFunc = 0
        Else
    FileSpec = DlgText("List1")
    If Left( FileSpec, 1 ) = "[" Then ' FileSpec is a directory
                PathName = Mid( FileSpec, 2, Len(FileSpec)-2 )
                DlgDirListA DlgHWND, PathName & "\" & fileExtension, nListID, nPathID, &h10
                If Right( PathName, 1 ) <> "\" Then
                    PathName = PathName & "\"
                End If
                DlgText "Text1", PathName & fileExtension
                Exit Function
            End If
            End If
            fileName = PathName & DlgText("List1")
            DlgText "Path", fileName
        End If
    End Select
End Function
Sub SavePatternName
' save the filename in Var(1-x) Len in 0
  Dim I
  Call SetVar(0,Len(fileName))
  For I = 1 To Len(fileName)
    Call SetVar(I,Asc(Mid(fileName,I,1)))
  Next I
End Sub
Sub GetPatternName
' get the filename in Var(1-x) Len in 0
  Dim lenStr, I, MyStr
  lenStr = GetVar(0)
  MyStr=""
  For I = 1 To lenStr
    MyStr=MyStr & Chr(GetVar(I))
  Next I
  fileName=MyStr
End Sub
Main
